Anyone have a/c with swap in crx?
Looking for anyone that has still been able to keep there a/c while having a swap in the car.
Have a 90si crx with b18c swap and would love to see anyone with a/c still in.
Warren
Warren
Alot of people have swpas and still retain there AC. My suggestion to you is keep your AC if you live in a hot area. Its not gonna make your car way faster if take it out. Make your own AC bracket or get an after market one. I am gonna use the Hasport one. If you are using a b18 you have to have Hasport specially make you a bracket because the ones they have are made to fit the b16 but unfortunetally the b18 has a different block design so therefore the bracket does not fit correctly. You can also buy the b16 bracket and modify it to fit your b18. Good Luck
I dont have a/c in it....i want to install it and want to see how others have done so....knowing that i have a b18c in there already...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nicks_jdmstyle_ef9 »</TD></TR><TR><TD CLASS="quote">If you are using a b18 you have to have Hasport specially make you a bracket because the ones they have are made to fit the b16 but unfortunetally the b18 has a different block design so therefore the bracket does not fit correctly. You can also buy the b16 bracket and modify it to fit your b18. Good Luck</TD></TR></TABLE>
All B-series motors can use the same A/C bracket.
I have hasport A/C bracket for sale for $50 if you are intersted? no pics of it installed. I just took my A/C out 20 minutes ago.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by StorminMatt »</TD></TR><TR><TD CLASS="quote">
All B-series motors can use the same A/C bracket.</TD></TR></TABLE>
You have no idea what you are talking about. Please get your info straight. I know what I am talking about. Maybe you should investigate before you make an *** out of yourself posting false info. The AC bracket will not fit on b18's. if you dont believe me then call Hasport on Monday so that they can tell you. Will you believe them??
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 4potnick »</TD></TR><TR><TD CLASS="quote">I have hasport A/C bracket for sale for $50 if you are intersted? no pics of it installed. I just took my A/C out 20 minutes ago.</TD></TR></TABLE>
pmed you
pmed you
PM'd about this.
PM'd about this.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nicks_jdmstyle_ef9 »</TD></TR><TR><TD CLASS="quote">You have no idea what you are talking about. Please get your info straight. I know what I am talking about. Maybe you should investigate before you make an *** out of yourself posting false info. The AC bracket will not fit on b18's. if you dont believe me then call Hasport on Monday so that they can tell you. Will you believe them??</TD></TR></TABLE>If you have full-race traction bar and maybe others you can use whatever A/C bracket you please.
Its not about the AC bracket clearing the crossmember. the b18 block has a different shape to it so the bracket does not sit up against it properly.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nicks_jdmstyle_ef9 »</TD></TR><TR><TD CLASS="quote">Its not about the AC bracket clearing the crossmember. the b18 block has a different shape to it so the bracket does not sit up against it properly. </TD></TR></TABLE>Sit up atgainst what? I was clearly stating that with full-race crossmember you can run the a?c bracket that came with the motor. I don't know anything about using b16 bracket on a b18 if thats what you mean. Just giving other options.
JUN.
Jun 11, 2008 06:18 PM
camel22
Apr 19, 2006 06:48 PM
Hapa88
Dec 19, 2004 08:12 AM
Dainbramage
Apr 21, 2004 01:29 PM
