No Sound In the Car...
i have a problem with cd player, i did bench test and everything works (including sound), but when i plug it in the car, it turns on but no sound.. i even used a speaker that worked on the bench test and nothing came out, so basically the cd player only works outside of the car...
any ideas why??
By the way its been working but when i washed my car and then got in like 30 mins later it didnt work
any ideas why??
ok..heres how its setup
Grounded to the car with aligator clips to make sure its grounded good
Only one speaker connected (one that was used in the bench test)
Hot Wire connected to Hot Wire on cd player
Memory wire connect to fuse box..
also it starts to get hot on the back right side of cd player
Its a honda civic si cd player, running in a 94 Civic
What year "honda civic si cd player" is it newer then 97/98?
Is the stock radio plug no longer in the 94?
What harness/plug have you got for the "si cd player"?
Things getting hot is an indication of shorted out outputs.
94
94Thread
EGgarniEG
May 30, 2007 02:02 PM
