Another EG Cluster Problem
Old Jan 28, 2006 | 04:44 PM
93preludeh22's Avatar
Default Another EG Cluster Problem
Friend gave me an EG cluster (AUTO.... my car is 5spd) with tach
Everything works with exception to gas/temp... He swears it worked before he gave it to me (freebie)
However, he removed the 6 screws to the gauge to remove gas/temp so he could tape over the drive/park/1/2/3 crap...
There are 3 screws of one size and 3 screws of a larger size. Where do they all go?
Thanks!
Old Jan 28, 2006 | 06:10 PM
egtwincam's Avatar
Default Re: Another EG Cluster Problem (93preludeh22)
the screwdriver used to take out the screws on the fuel temp gauag should not be magnetic at all. some how it damages the "4 bobbin coils" on the temp gauge.. you need another gauge now...
Old Jan 28, 2006 | 07:59 PM
BlueIntegraBoy's Avatar
You might have the wrong screws holding in the temp/fuel gauge. Each gauge has different size screws that are specific to each gauge. Remove the 3 screws that were holding the gauge on and swap it with the 3 other screws.
Old Jan 30, 2006 | 09:54 AM
Default Re: Another EG Cluster Problem (BlueIntegraBoy)
What size screws go into each side?
eg6style
Feb 4, 2009 08:59 AM
Cowl287
Jun 6, 2008 04:12 PM
SOHCex20
12
Sep 9, 2005 11:14 AM
WH0R3nEF9
Mar 28, 2005 06:50 PM
