How can I tell if rings are OK?
History: I was having oil buring problems with my mini-me. I originally had burned a valve in the A6 head, and this prompted mini-me. I rebuilt the A6 head while the Z6 was on the car.
I pulled off the head:
Cylinder three the head looks much blacker than the rest. This lead me to think it was the rings.
So I pulled out piston 3
It doesn't look bad to me, but I don't know what to look for. It doesn't look too black, but what are rings supposed to look like? Are the oil rings supposed to be pushed out, like the compression rings?
Hmmm... These rings seem to fit perfectly in the cylinder. Tight, but doesn't really take any pressure to get them in. I tried sliding the piston back in a tiny bit with only the oil rings on and a ring compressor was not needed. Well I hope the rings are the problem, as I have to replace them now!
inspect the top of your cylinder bore and feel for a lip on the sleeve. thats what was wrong with mine. so i bored .10 over and that didnt fix so then .20 and it was almost there and .30 over took care of it.
when I took out the pistons on my old d15b8 the rings on #1 fell apart in my hand in a bunch of pieces the second the piston came out. What you have isn't that bad, but may still need replacing.
31flavr... How much oil was it burning with the rings totally trashed? I am going through a quart every 750 miles or so. I want to try and figure out if this could be rings only, or if there is another problem?
Didn't feel stuck actually. I could rotate the oil rings easily. Maybe they came unstuck when I pulled them out? I did notice the spacing of the gaps was totally off spec, the two oil rings were 5 degrees apart or so. Engine has 166K on it.
I have already done some head work. Did the stem seals, lapped the valves... So I hope this is the last leak... Never know though, this is my first attempt at all this so I feel pretty noob about it all.
Is there any way to tell my head work went OK? Any way I can do at home without a pressure test?
Thanks all!
Thanks all!
About a quart every 2000 miles?? Problem is I didn't know my car burned oil, because my friends "forgot" to tell me that until after I pulled the bad rings out (because I never looked behind my car), so that prolly led to the downfall of the engine, because I NEVER added oil. It was a POS anyways so I didn't really care.
97grnrs
Apr 10, 2007 05:12 PM
4gencivicef9
Jun 27, 2006 05:51 PM
