Auto Tensioner Failing! Hoorayy!
Old Jan 28, 2006 | 12:50 PM
98TypeSH's Avatar
Default Auto Tensioner Failing! Hoorayy!
So i go out to my 98 SH this morning and fire it up. Doing my normal lap around the block to get out of my complex i hear some flapping noise, like a plastic bag is stuck under my car. I pull over and while its idling take a look at the T belt as i have the upper cover off. The belt is wobbling all over the damn place and slapping on the mount. i shut it off and pushed on the belt and KNOW it needs to be a hell of alot tighter then that. I just ordered all the Manual conversion parts. Unforunatly 2point6's rightup page is now a dead link. Ill have to PM him aboot that.
it lasted around 35-40K before it crapped out.
Old Jan 28, 2006 | 01:11 PM
fast+forward's Avatar
Default Re: Auto Tensioner Failing! Hoorayy! (98TypeSH)
https://honda-tech.com/zerothread?id=1196676 just did mine last wkend
Old Jan 28, 2006 | 02:00 PM
SteveoBA8's Avatar
Default Re: Auto Tensioner Failing! Hoorayy! (fast+forward)
Damn, very sorry to hear that.
Old Jan 28, 2006 | 05:13 PM
98TypeSH's Avatar
Default Re: Auto Tensioner Failing! Hoorayy! (SteveoBA8)
Well i took the opertunity to fix my fuct knock sensor as well. Just waiting till wednsday for all the parts for the swawp.
Old Jan 28, 2006 | 05:40 PM
cruzin89lude's Avatar
wait you can touch the timing belt with the valve cover off? Wait you were driving with the valve cover off? What was taken off so you could feel the T belt?
Old Jan 29, 2006 | 10:30 AM
98TypeSH's Avatar
Default Re: (cruzin89lude)
the upper timing cover was left off as i didnt have the bolt many moons ago. I can see the bottom of the cam gears and the belt as it rotates. Obviously dont stick your hand in the when the car is on, but you can see if it has excessive slack or not.
Old Jan 30, 2006 | 08:00 AM
cool, thanks. I wanna check on that too. That's the best way to tell your aut tensioner is going to hell? And yeah... you're sure you can't do it with the car on? That sounds like the most efficient way to do it, lol.
Old Feb 4, 2006 | 11:04 PM
if i didnt see this thread i'd probably still be driving with the bad AT till my car got F'd. Thanks man.
serjey15
Nov 27, 2010 03:50 PM
black94lude
Jan 5, 2010 04:04 PM
98TypeSH
Jul 14, 2006 07:28 AM
95accordh22a
May 18, 2005 01:37 PM
mountster27
Apr 15, 2003 04:38 PM
