si cluster into a std
got a std base with no tach on the cluster and i wonder if its as easy as swappin in an si cluster with a tach and would it work fine? ive heard you have to wire it all up and ****. if its gonna be that hard i aint gonna worry with it.
i have a std and put in a Si cluster and everything perfect, only problem is that at idle my rpms are steady, but once i give the car gas and take my foot off, the rpm needle slowly goes back down to idle, instead of just falling down quickly, even in neutral it does this, dont even know if this is my tachs problem or not just thought id bring it to your attention incase it happens to you.
