Anyone tell me the book labor rate???
why do you want to know? ill look it up tomorrow. it might vary from state to state so if youre trying to see if someone is ripping you off it might be different
threadjack: how about a timing belt/balance shaft belt w/ the following oil seals replaced?
14400-PT0-004 TIMING BELT
13405-PT0-004 BALANCE BELT
91233-PT0-003 BAL SHAFT SEAL
06923-P0A-306 BALANCE SHAFT SEAL RETAINER
15114-PT0-003 OIL DRIVE GEAR SEAL
91212-P0A-004 FRONT MAIN (CRANK) SEAL
91213-PT0-003 CAM SEAL
12341-PT0-000 VALVE COVER GASKET
19200-P0A-003 WATER PUMP
I’ve also got the timing & balance shaft tensioners:
14510-PT0-003 ADJUSTER, TIMING BELT (KOYO)
13404-PT0-004 ADJUSTER, BALANCE SHAFT BELT (KOYO)
chandlorexia
Oct 12, 2012 06:40 AM
treimche
Jul 2, 2006 05:40 AM
