Help 99 prelude h22a4 boggin problem
hello i have a 99 base prelude...my car keeps on bogging when the temperature barely is up to half around 1k-2krpms...when its cold it dosnt bog or after a while when the the car is really warm then it dosnt bog i clean my iacv and my egr valve anyone know the problem be possibly caused by?
any CEL's? you can try clearing the ECU memory and see if that helps. if it does, its a sensor giving false readings and the ecu is "learning" the new bad data. it might not be bad enough to trigger a cel, but bad enough to cause poor running. also, check to see if the O2 sensor is good. cold be any number of things...grounding comes to mind....
FearTheH
Sep 22, 2021 05:40 PM
zildjianmatt
Feb 11, 2010 07:09 AM
codyb13
Dec 27, 2005 02:27 PM
