Help with ZC rod and main bearings...
Old Mar 23, 2002 | 05:18 PM
travis_118's Avatar
Default Help with ZC rod and main bearings...
I need to find out specific what bearings fit the ZC engine. i have beend told by lots o people to use the 88-89 teg ones, but i need more specific details thatn that. if anyone can help PLEASE PLEASE help me out. thanks
Old Mar 23, 2002 | 05:37 PM
KS-R's Avatar
Default Re: Help with ZC rod and main bearings... (travis_118)
D16a6 bearings fit... Actually the ZC crank and the D16a6 crank is the same. I know.. cause Iv've used it before.
Old Mar 24, 2002 | 12:03 AM
CRX-RX's Avatar
Default Re: Help with ZC rod and main bearings... (KS-R)
You need the bearings from an 88-89 integra. The rod bearings are larger than any other D series, and require the use of that specific model. What more do you need to know about it?
This is to clear up for other people, I have been rebuilding a ZC for a freind of mine, and have had all the internals of a ZC and a D16 side by side sitting in my room. The rod ends are a full 1/8th of an inch apart from each other. Some people will claim that you can use D16 rods in a ZC engine, this is usually because they take it to a machine shop to be put together, and the shop will have to bore out the rod end to make it fit onto the ZC crank. If you don't want to beleive me I would suggest finding the specs in a manual, but I am telling you what I have learned from side by side comparison.
[Modified by CRX-RX, 4:14 AM 3/27/2002]
Mark Colglazier
Engine Machining & Assembly
Jan 29, 2019 09:12 PM
zenon8890
Jan 6, 2010 07:44 AM
Blue Streak
Oct 18, 2003 08:39 PM
Rob_hoody
Apr 30, 2002 06:18 PM
