timing belt
Old Jan 28, 2006 | 06:53 AM
hurleyint1386's Avatar
Default timing belt
can any one recommend a good timing belt for my 89 crx? i definitely want a good one. thanks a lot
Old Jan 28, 2006 | 08:15 AM
crxtreme89h's Avatar
Default Re: timing belt (hurleyint1386)
OEM
Old Jan 28, 2006 | 08:34 AM
ludesrv's Avatar
Stock motor...any T-Belt will do. OEM is the best.
Maybe Greddy makes one? They are really good belts but I doubt it for a D16A6.
Old Jan 28, 2006 | 12:21 PM
so if i buy a third party timing belt, would i need a timing belt kit or just a new timing belt?
Old Jan 28, 2006 | 01:21 PM
VtecSyndrome's Avatar
Default Re: (hurleyint1386)
Just buy an OEM timing belt from honda, have it installed correctly along with the cam seal, crank seal and water pump so you don't have to worry about that area again for some 90k miles. OEM belt is all you need because Honda T-belts are awesome quality!!!
Old Jan 28, 2006 | 01:25 PM
ludesrv's Avatar
A third party one will do the trick. I've used them on D series and they do last 100XXXkms, roughly 60XXX miles. Now, when you are doing a t-belt. Replace all the seals on that side and the waterpump since you already have that whole thing apart. OEM is the best for D series but it all depends on how much you care about your engine. On my D series, I feel no regret using regular third party stuff.
Old Jan 28, 2006 | 02:41 PM
31flavorscivic's Avatar
Default Re: (ludesrv)
OEM is $52 or something, I have no idea how much 3rd party is. Just FYI.
Old Jan 28, 2006 | 03:03 PM
imports automotive's Avatar
spoon t belt
Old Jan 28, 2006 | 06:37 PM
how much would the water pump be if the timing belt is changed too?
Old Jan 28, 2006 | 06:43 PM
Tippyman's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hurleyint1386 &raquo;</TD></TR><TR><TD CLASS="quote">how much would the water pump be if the timing belt is changed too?</TD></TR></TABLE>
Best place to get them: comes w/ water pump and it's all OEM.
http://prostreetonline.com/oem...t+Kit
Old Jan 29, 2006 | 11:58 AM
Default Re: (Tippyman98)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Tippyman98 &raquo;</TD></TR><TR><TD CLASS="quote">
http://prostreetonline.com/oem...t+Kit</TD></TR></TABLE>
Seems a little pricey! Also seems a bit overkill to just change your tensioner w/ your belt, I know they can go bad but it must be very rare because I have yet to see a tensioner need replacement so why blow your money???? Just go to Honda and p/u the Belt and water pump along with cam and crank seal, THATS IT no fancy package needed Just reaplce what Honda does when they do a Timing belt.
Old Jan 30, 2006 | 04:37 AM
Old Jan 30, 2006 | 07:19 AM
ghost_ryder35's Avatar
OEM parts are the best in my mind
Old Jan 30, 2006 | 08:02 AM
I got my water pump for $53 @ dealer.
Old Jan 30, 2006 | 09:10 AM
alupso's Avatar
You can get an OEM timing belt from slhonda.com for $34
http://www.slhondaparts.com/br...+BELT
Old Jan 30, 2006 | 10:23 AM
Just go to your Local honda dealer because it ranges from dealer to dealer. We have 3 dealers around here and 3 different prices depending on which one you go to. Just go to your Honda and get the right prices
blackccoupe
Jan 27, 2009 09:04 AM
shadow29485
Feb 1, 2008 05:44 PM
killacam661
Aug 30, 2007 04:34 PM
92integraVTECgsr
Jun 4, 2005 03:31 PM
Steak84SS
May 26, 2004 04:18 PM
