abs light is on and won't go off
Old Jan 28, 2006 | 06:40 AM
cdoucet's Avatar
Default abs light is on and won't go off
My abs light has come on and won't go out
My battery had died recently and had to get it boosted. Ever since then the abs light has come on and stayed on hasn't gone out.
I have tried the ECU reset procedure as well as the ABS reset procdure
(pulling the clock/radio fuse and the proer abs b2 fuse.)
Still the light stays on.
I tried jumper the p2 (brown/blue) to check the codes. I get nothing the abs light doesn't blink. Once I jumpuer the the connector the engine light will come on and not go out.
im lost and frustrated.
Chris
Car is a 93 prulde SRV
Old Jan 28, 2006 | 08:37 AM
BlueLude 94's Avatar
Default Re: abs light is on and won't go off (cdoucet)
check your brake fluid. For some reason I had this problem and i was my brake fluid.
Old Jan 28, 2006 | 09:22 AM
Ross 2.0's Avatar
In a Junkyard near you.
You set a code for low voltage. You probably tried to start the car on the dead battery and it wouldn't do it. Therefore it kicked the ABS code. What procedure are you using to reset the light?
Old Jan 28, 2006 | 09:27 AM
hu's Avatar
hu
One of your actual abs sensors might have gone out.
Old Jan 28, 2006 | 04:08 PM
cdoucet's Avatar
Default Re: (hu)
Blude lude.
Yeah i heard about that topped my break fluid off the other day still doesn't go out.
Moocow. Yup Your right I did.
According to the manual to do the reset, pull the abs b2 fuse out for atleast 3 seconds.
I tried that one and the cloak radio fuse to reset the ECU. that didn't work either.
I've tried this with and without the little jumper plugged in
MY starter has been acting up so I have been starting it manually by connecting to the 2 contacts on the starter with a piece of metal.
any ideas if this might make a difference?
Chris
bonstokLS
Mar 30, 2014 10:51 PM
Blaze45
Mar 12, 2013 02:59 PM
f22suzuka
Apr 21, 2004 10:15 AM
CNSK
Apr 12, 2003 11:13 PM
redteg1
Aug 18, 2001 02:42 PM
