New ECU, now it won't start!!?
Old Jan 27, 2006 | 09:58 PM
professor poon's Avatar
Default New ECU, now it won't start!!?
Alright, I finally got the OBD2 ECU (model number P72-A05) for my JDM B18C. I previously had the OBD1 Version of this ECU (p72-something). I plugged it in, disconnected the battery, reconnected it, and the car won't start. It turns over, but no ignition... This ECU should work, right? Any insight???
Old Jan 28, 2006 | 05:56 PM
Default Re: New ECU, now it won't start!!? (professor poon)
bump...
Old Jan 28, 2006 | 05:58 PM
egtwincam's Avatar
what year is the ecu? all 2000 acura ecu's have immobilizers built in and you would need to install the whole immobilizer system on your car....
Old Jan 28, 2006 | 06:07 PM
Default Re: New ECU, now it won't start!!? (egtwincam)
Might be a 2000...does anyone know the year from the model number: p72-A05
Old Jan 28, 2006 | 06:18 PM
egtwincam's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by professor poon &raquo;</TD></TR><TR><TD CLASS="quote">Might be a 2000...does anyone know the year from the model number: p72-A05</TD></TR></TABLE>
37820-p72-a05 is either a 2000 or 2001
37820-p72-a04 is a 1998 or 1999
Modified by egtwincam at 8:11 PM 1/29/2006
Old Jan 28, 2006 | 09:53 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by egtwincam &raquo;</TD></TR><TR><TD CLASS="quote">37820-p75-a05 is either a 2000 or 2001
37820-p75-a04 is a 1998 or 1999</TD></TR></TABLE>
you mean p72?
Old Jan 29, 2006 | 07:10 PM
egtwincam's Avatar
oops.. sorry was thinking LS computer.. rechecked it and it is the same with p72... you have a 2000-2001..
Old Jan 29, 2006 | 09:47 PM
Default Re: (egtwincam)
****. So would it even be possible or realistic to integrate the immobilizer system? If not, a '99 GSR ECU should work instead, right?
Old Jan 30, 2006 | 05:08 AM
Everyones Hero's Avatar
Default Re: (professor poon)
Did you check the fuse? I know egtwincam is probably right with the immobilizer thing, but check the fuse just to be 100%.
Old Jan 30, 2006 | 01:08 PM
egtwincam's Avatar
you can integrate the immmobilizer in your car but i believe for it to work.. you must have the vin# of the car that the ecu came out of. its needed for a honda scanner to program your immob..
Yes. you can use a 99 gsr. but. ecu connectors are different. youll have to change them.
Old Jan 30, 2006 | 01:09 PM
egtwincam's Avatar
oh and the immobilizer control unit and transponder assembly i believe cost at least 3 bills..
Old Jan 30, 2006 | 08:50 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by egtwincam &raquo;</TD></TR><TR><TD CLASS="quote">you can integrate the immmobilizer in your car but i believe for it to work.. you must have the vin# of the car that the ecu came out of. its needed for a honda scanner to program your immob..
Yes. you can use a 99 gsr. but. ecu connectors are different. youll have to change them. </TD></TR></TABLE>
So for that I just need an OBD2b &gt; OBD2a wiring harness. I'm fine with that, as long as the car starts this time...
Old Jan 30, 2006 | 09:07 PM
ILUVMYEM1's Avatar
well imobilizer is true.... loosk liek you'll need to get the older version seeing how ur key aint got the chip
v8killaz
Honda Civic (2001 - 2005)
13
Sep 11, 2008 03:33 PM
Greg50Lt
Honda Civic (2006 - 2015)
Nov 17, 2007 06:44 PM
I AM WEASEL
Jun 26, 2007 10:19 PM
integra-modder
Jan 7, 2004 07:07 PM
Champ R
Oct 26, 2003 02:51 PM
