BRAKE PROLEMS ON 88 CRX SI
Old Jan 27, 2006 | 09:15 PM
PDRIFT86's Avatar
Default BRAKE PROLEMS ON 88 CRX SI
wuts up ery 1? i just bought my crx about 3 weeks ago and its a great car which i plan on building up to an extent being that it is my daily driver. but not before i fix my dang brake situation.
ok about 3 days ago i noticed my front driver side rotor was GLOWING ORANGE when i got home from work and the next day i found that my clipers (front) where not fully releasing when not depressed. i've been tryin take care of the situation but so far no luck. i've replaced the MC, both calipers, the proportioning valve and the hoses. i havent replaced the rotors or pads yet because i'm waiting till this is solved as i want to install cross-drilled rotors w/ ceramic pads along with rear disc conversion from a da1 integra w/ cross-drilled rotors and ceramic pads. i want to remedy this problem first so as not to
warp my new rotors. i cant figure this out i need help!
the only thing left i didn't change is the booster. i didn't touch the rear yet but i don't notice any problems back there. i bench bled the MC before installing it and i also bought a vacuum pump to bleed the lines.
every thing was new except the PV that came from the junk yard. my pedal is really tight and firm, and pressure doesn't release from the calipers. could it be the used PV, air in the lines, do i have to adjust my pedal height or something. i don't know but i'm mreally pissed at all the $$$$$ i spent this week on brake stuff not to mention
the 2 days i called of work to fix this.
please help, any help will be greatly appreciated. thanks.
Old Jan 27, 2006 | 09:35 PM
civic889802's Avatar
i have the exact same problem brakes are compleatly gone on mines i change calipers,rotors,mc, i havent change the proportioning valve but will tomarow
i have calipers on the front n back they grab but just a lil n i have a 88 dx n some one told me i have to change the proportioning valve so my brakes grab i hoping that will fix my problem
Old Jan 28, 2006 | 05:36 AM
sam385's Avatar
Default Re: BRAKE PROLEMS ON 88 CRX SI (PDRIFT86)
also check the brake pushrod-to-booster clearance and the clearance between booster and MC. wrong adjustments here can cause 'mysterious' brake dragging problems.
Old Jan 28, 2006 | 06:16 AM
PDRIFT86's Avatar
yeah i'm gonna check it today. i was wondering if it is adjustable. some one told me this on one of my many trips to the parts store. i'm gonna buy the manual too. any pointers on adjusting the pushrod clearance?? thanks for the tip. hopefuly this is my problem.
Old Jan 28, 2006 | 08:28 AM
TallKyle's Avatar
Default Re: (PDRIFT86)
take off your calipers and take out those rods. Clean them with a wire brush and throw some grease on there. Make sure they move smooth. i had the same problem and that fixed it. Good luck
Old Jan 28, 2006 | 08:30 AM
ludesrv's Avatar
Getting enough vaccum to the MC. IF you have a horrid leak you get no brakes and a mushy pedal.
Old Jan 28, 2006 | 02:21 PM
PDRIFT86's Avatar
thx 4 da help guys but i think ive found the problem. its either the brake booster or that check valve on the vacuum line. when i disconnected the hose at the intake it didn't do nothing, but when i disconnect it from the check valve it released some pressure and the calipers loosened up immediatly !
arrg!!! all the money i spent and it was something dumb. ive been driving around all day
with the booster disconnected and my brakes are fine other than being hard due to the lack of power assist. but they are not sticking any more
i'm gonna replace the check valve first and then the booster if needed. it looks like a biznatch to remove cause its cramped under the dash.
Old Jan 28, 2006 | 02:33 PM
sanimalp's Avatar
$cat /dev/urandom
you *might* not want to go with cross drilled rotors.. the crack really easily.. and even brembo cross drilled rotors aren't warrented because of this.
Old Jan 28, 2006 | 06:46 PM
Default Re: (sanimalp)
i replaced everything mc resivor box n 1 caliper n my brakes still not working can any one help me
Old Jan 29, 2006 | 07:00 PM
sanimalp's Avatar
$cat /dev/urandom
Default Re: (civic889802)
i had a similar problem you did, and i solved it by just rebuilding the master cylinder i had. the one that autozone insisted was the correct one was infact not.
are they still doing the exact same thing? or is it something different now.
ryanangelo212
Jun 3, 2013 11:42 PM
cmyates007
18
Apr 14, 2012 10:19 PM
Romo Pyro
Nov 15, 2010 05:31 PM
Zeppelin
Jun 7, 2004 07:49 PM
seer_claw
Feb 24, 2004 08:13 PM
