Arc Flutter
Old Jan 27, 2006 | 06:19 PM
civicracer1600's Avatar
Default Arc Flutter
I have an issue with welding aluminum. I usually weld steel for rollcages, etc. But recently we have been thinking about building custom aluminum peices. I use a thermal arc 185 tsw welder and i am welding 1.5mm thick sheet aluminum. any advice on welder setting would be appreciated. when i start a weld the arc will constantly flutter up to about 1/8 inch from where i am welding. I imagine that a/c welding will yeild this result to a point, but in this case it seems excessive.
Old Jan 27, 2006 | 07:19 PM
k24em2's Avatar
Default Re: Arc Flutter (civicracer1600)
Thats the HF usually. When you give it some more pedal it should straighten up.
Old Jan 27, 2006 | 08:17 PM
Race Egr's Avatar
Default Re: Arc Flutter (k24em2)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by k24em2 &raquo;</TD></TR><TR><TD CLASS="quote">Thats the HF usually. When you give it some more pedal it should straighten up.</TD></TR></TABLE>
yea, thats how mine works pretty much my arc dosent flutter that bad at all though and i have the same welder. I see your in maryland where exactly in md are you?
Old Jan 28, 2006 | 05:11 PM
kranked91dx's Avatar
Default Re: Arc Flutter (NAPIER)
a few thing's I know will cause fluttring...
if you are using a ball pointed thungsten with an advanced square wave patern, it will cause flutter. you need a pointed thungsten.
lack of Argon flow will cause flutter, but also carbon mark and brown haze all over the place...
A contaminated thungsten will cause fluttring of the arc too...
hope this help.
jp
Old Jan 28, 2006 | 06:04 PM
My shop is in aberdeen, md (about 30 mins north of baltimore)
Old Jan 29, 2006 | 11:58 AM
kpowerdhatch's Avatar
make sure to clean your aluminum with a wire brush to remove aluminum oxide before welding. aluminum will usually take a higher heat setting also compared to steel. what kind of tungsten are you using? 98% tungsten?
Briang3a3
Welding / Fabrication
Jan 13, 2008 12:14 AM
HT Chaplain
27
Aug 20, 2007 06:48 AM
*Boostwerks*
36
Jan 6, 2007 12:43 PM
*Boostwerks*
18
Nov 23, 2005 02:11 PM
vegaskurt
Mar 1, 2005 05:49 AM
