Vaccum Etiquette
Old Jan 27, 2006 | 04:17 PM
trrbl1bmx's Avatar
Default Vaccum Etiquette
Does anyone have the "Do's and Don'ts" with removing vaccum lines/ emissions from EF chassis civic. I want to get rid of some unneeded pieces in my engine bay. pics would be awesome.!
Old Jan 27, 2006 | 05:05 PM
eda6's Avatar
Default Re: Vaccum Etiquette (ilovemyef9)
I have 3 vacuum lines on my car.
fpr, brake booster and pcv. The map sensor is mounted on top of the throttle body.
All other vacuum lines and emission components were removed.
Modified by eda6 at 9:20 AM 1/28/2006
Old Jan 28, 2006 | 04:02 AM
trrbl1bmx's Avatar
bump
Old Jan 28, 2006 | 04:16 AM
Stoich's Avatar
Default Re: Vaccum Etiquette (eda6)
same here i have only 3 hooked up to my B18
Old Jan 28, 2006 | 05:27 AM
sam385's Avatar
Default Re: Vaccum Etiquette (Stoich)
removing emissions control devices in many jurisdictions can get you in a big heap of trouble my advice on this subject is: Don't remove these items on any street ride.
'Give a Hoot; Don't Pollute'
Old Jan 28, 2006 | 08:16 AM
crxtreme89h's Avatar
Default Re: Vaccum Etiquette (sam385)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sam385 &raquo;</TD></TR><TR><TD CLASS="quote">'Give a Hoot; Don't Pollute'</TD></TR></TABLE>
Trees are Terrific!
Old Jan 28, 2006 | 08:29 AM
ludesrv's Avatar
Currently running no charcoal canister. Only having 3 vaccuum lines removes the thought of a vaccum leak when concidering a shitty idle haha.
It's ok if it's on a no so street driven car. Luckily my EF is a 100% stock looking car with stock exhaust. They wouldn't check anything.
Old Jan 28, 2006 | 02:00 PM
trrbl1bmx's Avatar
I live in sc and emissions is not a big deal. You could run a small block ford on a shopping cart as long as you have a liscense, registered, and insured..
Old Jan 29, 2006 | 08:57 AM
trrbl1bmx's Avatar
bump for more pics
Old Jan 29, 2006 | 10:44 AM
trrbl1bmx's Avatar
more pics of sohc with charcol canister removed. and the peice that is on the firewall what do i do all the nipples left open.?
Old Jan 29, 2006 | 02:37 PM
trrbl1bmx's Avatar
Old Jan 29, 2006 | 02:53 PM
Beau Gotti's Avatar
i would guess just block the open nipples off?
im thinking of removing alot of the Emissions stuff before i swap my B series in
does it affect car idle, or rid,e if you block the stuff off?
Old Jan 29, 2006 | 08:47 PM
Beau Gotti's Avatar
bump
Old Jan 29, 2006 | 08:54 PM
AJxr's Avatar
Default Re: (Beau Gotti)
i would also like to know, also if anyone has any pics of where they ran the lines etc. post em up! i think where i live there is no emissions on anything 95 or older... not 100% sure though so this is something i look into to clean up my bay, wire tuck wasnt enough!
Old Jan 30, 2006 | 04:40 PM
trrbl1bmx's Avatar
bump for more info
Old Jan 30, 2006 | 06:49 PM
AJxr's Avatar
Default Re: (ilovemyef9)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ilovemyef9 &raquo;</TD></TR><TR><TD CLASS="quote">bump for more info</TD></TR></TABLE>
Old Jan 30, 2006 | 06:51 PM
trrbl1bmx's Avatar
someone knows something
Old Jan 30, 2006 | 09:21 PM
Beau Gotti's Avatar
i just want to know if i can tke that thing next to the fuel rail, and the thing on the firewall with all the vaccume hoses running to it off and just block everything off, and be good.
Old Jan 30, 2006 | 09:35 PM
VtecSyndrome's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ilovemyef9 &raquo;</TD></TR><TR><TD CLASS="quote">I live in sc and emissions is not a big deal. You could run a small block ford on a shopping cart as long as you have a liscense, registered, and insured..</TD></TR></TABLE>
and that is why SC drivers scare me so much, there are just crazy and don't know how to drive (of course a few have common sense yourself included I hope )
Old Jan 31, 2006 | 05:27 PM
trrbl1bmx's Avatar
yeah sc drivers do suck. tonight im sitting at a stoplight and some little kids are in a mini van with their dad and i guess they were snickering about my Spoon stickers under my mirrors that have the S taken off so they say POON. Next thing I know, all I hear is the van peeling out down the road. It's like do people have nothing better to do.
Old Jan 31, 2006 | 07:37 PM
crx2ner's Avatar
will this work with any motor set up? ive got a y8 and have a horrible idel right now so planned on re doing all my vacuum lines, and did u just cap off all the others? if so where did u get the caps/plugs?
Old Jan 31, 2006 | 08:41 PM
eda6's Avatar
Default Re: Vaccum Etiquette (crx2ner)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ilovemyef9 &raquo;</TD></TR><TR><TD CLASS="quote">someone knows something </TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by eda6 &raquo;</TD></TR><TR><TD CLASS="quote">
The pic is a p30 manifold.
make sure the map, fpr, booster, and pcv are connected to the intake manifold. Remove purge solenoid and charcoal canister. Leave the map sensor if it's firewall mounted. DO NOT CAP OFF the red hose on the firewall (next to the fuel filter). Now check your throttle body and intake manifold carefully to make sure it's completely sealed. That's all there is to it.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by crx2ner &raquo;</TD></TR><TR><TD CLASS="quote">if so where did u get the caps/plugs?</TD></TR></TABLE>
DAP and autozone have them.
Old Jan 31, 2006 | 08:44 PM
AJxr's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by eda6 &raquo;</TD></TR><TR><TD CLASS="quote">DO NOT CAP OFF the red hose on the firewall</TD></TR></TABLE>
so what, just leave it unhooked?
Old Jan 31, 2006 | 08:48 PM
eda6's Avatar
Default Re: Vaccum Etiquette (AJxr)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by AJxr &raquo;</TD></TR><TR><TD CLASS="quote">
so what, just leave it unhooked?</TD></TR></TABLE>
yes. That hose supplied the charcoal canister with fuel vapors. Let it vent to the atmosphere.
B16A CRX
Mar 20, 2008 04:53 PM
civicflow
16
Jun 7, 2007 10:50 AM
efyou
Dec 22, 2005 03:21 PM
turbotime
Oct 6, 2005 11:30 AM
VTECAcuraGSR
25
Mar 30, 2005 02:28 PM
