no fuel coming to oil filter at all
Old Jan 27, 2006 | 02:17 PM
crnimacak's Avatar
Default no fuel coming to oil filter at all
hey i need help badly.I did alot and still no problem solved.Anyways lets get to a point.I have a honda civic hatch 92.It doesnt want to start.I changed a fuel relay and that is not a problem,also i changed a fuel pump but still problem not solved.Wat it can be i need help pls tnxs
Old Jan 27, 2006 | 02:32 PM
alotawatts's Avatar
Default Re: no fuel coming to oil filter at all (crnimacak)
I don't think you want FUEL comming to your OIL filter....do you ?
..Ummm...you mean Fuel filter ?
You should be able to electronically test the pump and relay. Someone else here will know...
Old Jan 27, 2006 | 02:35 PM
sgtroseberry's Avatar
Default Re: no fuel coming to oil filter at all (alotawatts)
run spell check please
Old Jan 27, 2006 | 03:01 PM
Mohsin's Avatar
Default Re: no fuel coming to oil filter at all (sgtroseberry)
If you aren't going to post a solution then get out of the thread and dont bother posting in the first place.
It seems as if the Main relay may have dry joints. I had the same problem, I located the main relay (under bonnet lever), encased in a grey holder. Unscrew, and then re-solder the dry joints. Since i have done this no problems what so ever. It was embarrasing ending up at the fuel pump to wait 15mins before i could start the engine up.
More Info: http://autorepair.about.com/cs...c.htm
Old Jan 27, 2006 | 03:29 PM
Luserkid's Avatar
Default Re: no fuel coming to oil filter at all (Mohsin)
What exactly is the problem? Fuel pump not priming or something? Did you check your grounds?
Old Jan 28, 2006 | 03:59 AM
crnimacak's Avatar
Default Re: no fuel coming to oil filter at all (Luserkid)
yea fuel filter my bad.and yea i changed a fuel relay man twice i tho that was the problem.it starts up and yea i turn it of and then i try to start it up again it wont start.then i wait like 15-20 mins and it starts again.i dunu wtf it is
Old Jan 28, 2006 | 04:07 AM
92civichatch1's Avatar
def. your main relay my 92 hatch did the samething. she would die while driving and id sit around and wait 15 min and she would all of a sudden fire up and run like normal. Get a new main relay.
Old Jan 28, 2006 | 04:11 AM
Default Re: no fuel coming to oil filter at all (92civichatch1)
If you dont know where it is... its on the driver side down and further left than the fuse box. If you lay down and look under (asssuming you lay down and the gas pedal is to your left and clutch pedal to your right) Look at the fuse box and slowly look down a bit more and right more you should see a grey cap over a brown relay. The grey cap usually has white writing on the top. Thats the main relay.
Old Jan 28, 2006 | 07:57 AM
onegreedy's Avatar
i had this problem it was bad ecu
Old Jan 28, 2006 | 08:41 AM
SL!M's Avatar
How do you know its a fuel problem? Have you checked for spark? Have you checked your plugs, do they have fuel on them? And disconnect one of your fuel lines and check compression in the line, preferably the feed line, to see where your problem lies. I hope this helps.
Old Jan 28, 2006 | 07:15 PM
crnimacak's Avatar
okey im kno its fuel problem becouse there is spark i checked that first dahhh then i checked on the fuel filter if there is any gas coming tro and there was non at all sometimes maybe 1-10 it starts and thats when oil comes up on the oil lines and yea i changed relay twice and same thing first it would start right away when i change it but then after i turn the car off it would start at all so i dunu wtf it is man ****
Old Feb 2, 2006 | 04:36 PM
SL!M's Avatar
it was difficult to read that with absolutely no punctuation but.... I dont understand what you mean by the oil comes up, do you mean your oil pressure comes up? What is the correlation between your fuel problem and the oil you are mentioning?
2.2lude88
May 26, 2009 09:05 PM
EGKREW
Nov 26, 2008 11:54 AM
mikester1222
Nov 16, 2008 05:16 PM
jdmoutkast
Jul 7, 2007 12:21 AM
diewX3
Jan 11, 2005 11:50 AM
