Brake lines, fittings, and line tucking!
Old Jan 27, 2006 | 01:18 PM
HybridKOOP's Avatar
Default Brake lines, fittings, and line tucking!
Howdy everyone...
This weekend I am moving onto my brake line tuck which will relocate my prop valve and lines behind the dashboard on the firewall.
Would anyone know the best place to buy hard lines, fittings, line bender, and flare tool necessary for this? As always... I will post pictures of my progress! Thanks!
- Louis
Old Jan 27, 2006 | 01:29 PM
wantboost's Avatar
Who is Mr Robot?
Default Re: Brake lines, fittings, and line tucking! (HybridKOOP)
i got 75ft of 3/16th line off of ebay for 25 bucks. a local guy to me sells benders pretty cheap, also sells them on ebay, like 19 bucks or so.
as for a flare tool, the 45* tools can be bought at home depot or lowes, or you can just do it on ebay, lol.
the fittings you could get from summit or jegs.
if you want ill look up who exactly i got the line and bender from
Old Jan 28, 2006 | 09:23 PM
Rosko's Avatar
Default Re: Brake lines, fittings, and line tucking! (wantboost)
O'reilly's sells straight sections i think 5 ft. long.
Old Feb 18, 2006 | 09:30 AM
2 0 3's Avatar
Default Re: Brake lines, fittings, and line tucking! (Rosko)
have u looked into nhra rules as far as brake line routing ?
from what im reading ...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote &raquo;</TD></TR><TR><TD CLASS="quote">Brake lines must be steel,
steel-braided, or DOT-approved flexible and routed outside the
framerail
, or enclosed in a 16-inch length of 1/8-inch-minimum wall-
thickness steel tubing securely mounted where line(s) pass
the flywheel bellhousing area and not routed in the driveline tunnel.
All brake lines must be attached to chassis as per OEM style;
hoses must have mounting brackets; no tie wraps, tape, etc.</TD></TR></TABLE>
just curious how u plan on routing any steel braided lines...
heres some pics from my setup last year.
*note the lines dropping down from the master into the chassis of the car.
i wonder if that would pass tech ? i never tried.
Old Feb 18, 2006 | 09:33 AM
2 0 3's Avatar
Default Re: Brake lines, fittings, and line tucking! (EallmotorF)
just found a better pic.
u mentioned hard lines and benders so maybe this isn't any concern to you, but this is how i was planning on running my lines again on the new car. hmmm.
Old Feb 19, 2006 | 12:31 PM
Chase's Avatar
Sorrry to be OT but EallmotorF, whatd u use to paint ur bay?
Also in for answers. Im tucking my Brake lines as well with new hardline.
Old Feb 20, 2006 | 09:43 AM
6MTV6's Avatar
Default Re: Brake lines, fittings, and line tucking! (EF8kid)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EF8kid &raquo;</TD></TR><TR><TD CLASS="quote">Sorrry to be OT but EallmotorF, whatd u use to paint ur bay? </TD></TR></TABLE>
Looks like that old skool GM or Ford Trunk paint w/ the different colors in it.
Old Feb 20, 2006 | 03:31 PM
2 0 3's Avatar
Default Re: Brake lines, fittings, and line tucking! (6MTV6)
OT again sorry guys...
...actually its krylon wrinkle black, then stock phantom grey painted over it.
so stock color, just with a texture..
Old Feb 20, 2006 | 03:38 PM
2 0 3's Avatar
Default Re: Brake lines, fittings, and line tucking! (on_motor_only)
so HybridKOOP , u plan on rerouting using hardline ?
i know these guys were great to deal with when i orded all my fittings last year,
they also carry hard line stuff...
http://www.performanceplumbing.com
take a look.
Old Feb 21, 2006 | 12:09 AM
B18C_eg's Avatar
if your gonna be bending hard line to re-route then just use the oem fittings that you will be removing. save some money, just be careful when loosing them cause cause theyre kinda soft material.
i got a line bender, flare tool and pipe cutter from home depot in the plumbing section. so if u got a home depot or lowes or whatever you have over there on the east coast, check there first. ive seen hardlines at a local parts store like schucks, carquest or autozone.
Old Feb 27, 2006 | 09:07 AM
Pworld's Avatar
From: somewhere in INGLEWOOD chillin in tha hood, CA
Default Re: Brake lines, fittings, and line tucking! (B18C_eg)
When you guys bent your hardlines. did you have one piece going all the way from the Prop Valve to the fenderwell?? for the brake line, or did u have to fit, like 2, or 3 different sections together, to get the route u wanted on the hardline??
Old Feb 27, 2006 | 10:27 AM
B18C_eg's Avatar
Default Re: Brake lines, fittings, and line tucking! (Pworld)
do it all as one piece.......and if you trying to hide it you can run it under the frame rail into the inside of the fender well (staying out of the engine bay all together)
Old Feb 27, 2006 | 02:04 PM
Diego Dangers.'s Avatar
NAPA sells all of that.
Old Sep 16, 2007 | 02:00 PM
k0rean4life's Avatar
any pics of the process
Old Sep 16, 2007 | 02:15 PM
ls1_datsun's Avatar
Default Re: Brake lines, fittings, and line tucking! (k0rean4life)
I got all the fittings and SS Line from Summit. I got the AN flare tool and tube bender from a local hydrualic store. I dont' really care about racing sanctioned events so not really concerned with nhra rules...
Old Sep 16, 2007 | 06:43 PM
ShawnR's Avatar
Default Re: Brake lines, fittings, and line tucking! (ls1_datsun)
few pics of mine im plan on racing sfwd hope they dont say anything
Old Sep 16, 2007 | 11:02 PM
paulzy's Avatar
Default Re: Brake lines, fittings, and line tucking! (97gsrcoupe)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 97gsrcoupe &raquo;</TD></TR><TR><TD CLASS="quote">few pics of mine im plan on racing sfwd hope they dont say anything
technically, that's still on the otehr side of the firewall though isn't it?
Old Sep 17, 2007 | 08:41 AM
preludestud11's Avatar
I dont see winshield wipers, and you must have those to race sfwd.
Old Sep 17, 2007 | 10:41 AM
ShawnR's Avatar
Default Re: Brake lines, fittings, and line tucking! (preludestud11)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by preludestud11 &raquo;</TD></TR><TR><TD CLASS="quote">
I dont see winshield wipers, and you must have those to race sfwd.</TD></TR></TABLE>
cuase the car is about to get painted i took everything out but they will be on the car when race time comes around
Old Sep 17, 2007 | 11:35 AM
Justin Olson's Avatar
Can you replace hard lines with flexible braided lines w/ AN fittings?
Justin
Old Sep 19, 2007 | 07:53 AM
pgpbubble's Avatar
Default Re: Brake lines, fittings, and line tucking! (Justin Olson)
Where did you get your 10x1.0 to -3AN fittings in blue from? All I can find is silver; and they wont even screw down all the way.
Old Sep 19, 2007 | 08:46 AM
ShawnR's Avatar
Default Re: Brake lines, fittings, and line tucking! (pgpbubble)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by pgpbubble &raquo;</TD></TR><TR><TD CLASS="quote">Where did you get your 10x1.0 to -3AN fittings in blue from? All I can find is silver; and they wont even screw down all the way.</TD></TR></TABLE>
custom made
Old Sep 19, 2007 | 08:19 PM
8mpg's Avatar
dont use a crapy flaring tool. I highly recommend a Rigid brand flaring tool.
Old Sep 20, 2007 | 05:18 AM
tepid1's Avatar
Default Re: Brake lines, fittings, and line tucking! (rota92)
Yeah his lines are done up. They used hardline throught the engine bay.
Old Sep 20, 2007 | 07:03 AM
ShawnR's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by rota92 &raquo;</TD></TR><TR><TD CLASS="quote">
Thats really personal preference, LOTS of places (like my old work where we made high pressure stainless hose assemblies) will simply not do brake lines for anything. I even had to buy my stainless replacements from an aftermarket company instead of making them during lunch lol
They aren't really intended for this type of use, but there are guys that do it and they seem to have it work okay.
I wouldnt do it when you need to rely on them though...which for most people is all the time lol
I will do stainless teflon for my rear brake setup on a solid rear axle most likely though. There isn't that much weight and its super easy to work with! (But its for staging only)
Lou, did you ever do this yet?</TD></TR></TABLE>
yea i had heard that most places dont do break lines but the place i went to never asked what i was gona use them for...
justinball1717
Honda Civic (2001 - 2005)
Oct 24, 2016 06:43 PM
ESP.net
Suspension & Brakes
May 29, 2010 09:19 PM
Paprika
Nov 28, 2004 01:14 PM
jolt-tsp
20
Sep 2, 2003 10:10 AM
