preping lip for paint...
Old Jan 27, 2006 | 09:35 AM
Project_EK's Avatar
Default preping lip for paint...
what up,
i just got a brand new OEM black SI lip and i'm going to get it painted white, but how should i go about sanding it so the paint bonds better?? what grit should i use and how far should i go? i'm thinking i just need to take off the clear coat?!?!
thanks
also is 400grit okay?
Old Jan 27, 2006 | 09:45 AM
Project_EK's Avatar
up...
Old Jan 27, 2006 | 01:35 PM
Project_EK's Avatar
Old Jan 27, 2006 | 04:02 PM
Project_EK's Avatar
upppppppppp
Old Jan 27, 2006 | 04:30 PM
highrolla's Avatar
Default Re: (EKhatch219)
is it primed or raw, if it is raw you need to bake it in a booth first then wash it down with a solvent to open up the pores of the plastic i use 902 made by diamont then sand it with 800, if it came primed then hit it with 500 wax and grease remove it 2-3 coats of base depending on the brand paint, and then 2 coats of clear
Old Jan 27, 2006 | 07:01 PM
Project_EK's Avatar
lol thanks for the tips but i dont think u understanded me...i bought an OEM si lip that came painted SI black from the factory. im taking it to get painted at a shop, but i want to prep it so all they have to do is primer n paint...if they paint it now without me sanding it the paint wont stick...so i'm asking what grit i should use to sand it down?!? thanks
Old Jan 27, 2006 | 07:21 PM
RC_SKUBY's Avatar
hit it with some 320 and it should be cool if it has a existing finish
Old Jan 27, 2006 | 07:27 PM
powerflow's Avatar
I would use 600-800 and sand it until the surface is flat, no peel and check for imperfections.
Old Jan 27, 2006 | 07:29 PM
95-EJ1's Avatar
Default Re: (powerflow)
scuff it...wet sand with 400. then paint!
Old Jan 27, 2006 | 07:55 PM
DUFFM4N's Avatar
Default Re: (95-EJ1)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 95-EJ1 &raquo;</TD></TR><TR><TD CLASS="quote">scuff it...wet sand with 400. then paint!</TD></TR></TABLE>
^^listen to this guy...he's painting his own car and doing all the prep work himself
Old Jan 27, 2006 | 08:58 PM
Project_EK's Avatar
thanks
Old Jan 28, 2006 | 04:25 PM
highrolla's Avatar
you obliviously didnt understand my response, ive been painting cars for 3 years now. When you buy parts from the factory the either come pre primed or raw, if you bought and lip that was pereviously installed on a car then it is alreday based and cleared. That my be where i lost you if that is the case, hit it with 500 and you will be good to go, and if you bought it directly from the factory do as i stated in my last pos,t, sorry if i misunderstood
Old Jan 29, 2006 | 05:43 PM
EK [30-85]'s Avatar
Yeah 95-EJ1 is correct. Wet sand it with 400....also if there is any scratches or gouges knock those off with 400 as well. wet sand in long strokes and not jus sand on 1 spot with short storkes u'll dig through the surface if u don't sand evenly. after u have scuffed up the lip and taken any possible gouges (imperfections) out, get a gray colored FINE scotch brite and go over the whole lip, ESSPECIALLY the edges. doing this will guarentee u scuffed up the whole lip and the edges. edges is the most important for paint to NOT peel!!!! . im a painters prepper just to let u know.
Zaraki
Paint and Body
May 21, 2008 03:24 PM
ziptie
Paint and Body
Aug 6, 2007 08:09 AM
BAYgasDC2
Aug 19, 2005 02:29 PM
JDubya
May 13, 2004 09:18 AM
redline201
14
Sep 9, 2002 10:02 AM
