squeeking when turning steering wheel
Old Jan 27, 2006 | 07:01 AM
hurleyint1386's Avatar
Default squeeking when turning steering wheel
for a few days now, when ever i turn in my crx, i hear a squeeking noise. it's kind of hard to explain, but that's the best way i can think of. i'm not sure what it could be. any thoughts would be much appreciated. thanks a lot.
Old Jan 27, 2006 | 07:03 AM
Sequoyah's Avatar
Default Re: squeeking when turning steering wheel (hurleyint1386)
I've been hearing the same thing as well. My initial thought is that is was the plastic covering the steering column rubbing against the back of the steering whell, but I haven't investigated yet. If so, I think a little shot of silicone spray would do the trick.
Old Jan 27, 2006 | 07:10 AM
Default Re: squeeking when turning steering wheel (Sequoyah)
so it's nothing too serious to worry about or anything. ill try to silicone spray once i get home from college so it might be a month or 2
Old Jan 27, 2006 | 10:12 AM
Tyson's Avatar
take off your steering wheel and grease the metal contact ring.
pry off the H emblem to get to the 19mm nut.
Old Jan 27, 2006 | 11:01 AM
george34's Avatar
Default Re: squeeking when turning steering wheel (Tyson)
I think most CRX steering wheels squeek when it is cold.
Old Jan 27, 2006 | 11:14 AM
manson's Avatar
Default Re: squeeking when turning steering wheel (george34)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by george34 &raquo;</TD></TR><TR><TD CLASS="quote">I think most CRX steering wheels squeek when it is cold. </TD></TR></TABLE>
they don't when you lube them.
Old Jan 27, 2006 | 12:35 PM
Jerms's Avatar
thats right lube them up and it will go away
uptownspeedstar
Feb 25, 2011 04:21 PM
gpdxtrm
13
Dec 28, 2007 08:10 PM
VTEC-LUDE
Jan 7, 2007 06:42 AM
pvt. snowball
Honda Civic (2006 - 2015)
16
Aug 18, 2006 07:30 PM
b18c-1
Oct 1, 2005 08:48 PM
