92-95 civic wiring diagram pleaseeeeeeeeee help need asap
go to pep boys or your local auto supply store and pick up a Helms or Chilton Manual. They got it in there. It's good to have to book so you can have it with you while your workin on your ride. Goodluck, Peace
U will also need to connect relays if you plan to hook up power locks. relays can be bought at kreggen/autozone etc.
| ITEM | WIRE COLOR |POL| WIRE LOCATION |
| 12V|white |+ |steering column |
| STARTER|black/white |+ |steering column |
| IGNITION|black/yellow |+ |steering column |
| SECOND IGNITION| | | |
| ACCESSORY|yellow |+ |steering column |
| POWER LOCK|green/white |- |2pin plg blue-taped to |
| POWER UNLOCK|green/red |- |blue plg behind f-box |
| PARKING LIGHTS +|red/black | |at fuse box or d.k.p |
| PARKING LIGHTS -| | | |
| HEADLIGHTS|red/white |+ |column (low beam only) |
| DOOR TRIGGER|lt. green/red |- |driver kick panel |
| TRUNK/HATCH PIN|grn/blk 2 sil.dot *1|- |blue conn. above fusbx |
| HOOD PIN| | | |
|TRNK/HTCH RELEASE| | | |
| FCTRY ALARM ARM| | | |
|FCTRY ALRM DISARM| | | |
| TACHOMETER|blue | |2-pin conn. near dist. |
| BRAKE WIRE|green/white |+ |at brake switch |
| HORN TRIGGER|blu/grn, blu/red *2 |- |at steering column |
| WIPERS| | | |
| LF WINDOW UP/DN|red/yellow - red/blu|A |drivers switch |
| RF WINDOW UP/DN|blue/yel - blue/grn |A |drivers kick panel |
| LR WINDOW UP/DN|yellow - yellow/grn |A |dkp, harness to rear |
| RR WINDOW UP/DN|yellow - yellow/grn |A |dkp, harness to rear |
| HOOD PIN| | | |
| WIPERS| | | |
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by john666 »</TD></TR><TR><TD CLASS="quote">U will also need to connect relays if you plan to hook up power locks. relays can be bought at kreggen/autozone etc.
| HOOD PIN| | | |
| WIPERS| | | |
Nope, thats only if you are ADDING door lock actuators. If the car already has power locks, then you don't need relays.
| HOOD PIN| | | |
| WIPERS| | | |
usally 92-95 civics hb im guessing from the avatar dont have power w. but if u did change the doors from a ex yea u dont need relays .
i really confused about this
manual arm input
unlock switch input
instant trigger
neg door trigger
maunal disarm input
pos door trigger
armed output
manual arm input
unlock switch input
instant trigger
neg door trigger
maunal disarm input
pos door trigger
armed output
mr2kqql
Jun 6, 2015 09:52 PM
