What do you all think of this.. Backdoor IC conversion?
Hi, i got a steal on a small precision IC.
My plans are to have the inlet cut off, and a cap welded, then the front of the end tank drilled and the outlet welded on there.
The comressor outlet will line up good, and i will use much less piping.
Bumper wont be perfectly cenetered (3" out) but it will be painted flat black anyways.. so it will be hard to see.
I cant do the IC piping any other way (shitty mani design/clearance) I cant go down though the windshield bottle because its a huge ramhorn and the pipe wont fit between #1 runner, and the headlight frame piece.. and i cant go 90 off bottom and between radius rods (turbo clocked down) then 180' into IC.. and i dont want to go under becaues ground clearance will blow ***
Other side of IC is done.. fits mint.
So what do you say to the backdoor style
or
Ill get some pics up tommorow of exactly what i want to do..
or
I was running a SRT4 intercooler with some modified end tanks so drivers side was back door and passenger side regular side exit.Worked perfect on a EF as I came off the turbo right into the compressor outlet and into the intercooler.The CRX Im building know will get the same setup as I need to keep my washer fluid jug where I live so it has to go through the rad support area.
Check out this thread for ideas. https://honda-tech.com/zerothread?id=1339065
Also, I followed his format with a twist since my core wasn't as wide, we just chopped inlets and used half of a 180 bend on each side to make for a pseudo backdoor without having to fit couplers up front.
Click for larger and you can sorta see what we did.
[/url]
Engine bay is dirty, but you can see how we routed piping down, note that its all mandrel bends.
.jpg)
[/url] Engine bay is dirty, but you can see how we routed piping down, note that its all mandrel bends.
.jpg)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by shortyz21 »</TD></TR><TR><TD CLASS="quote">i love how only 1 bolt is holding the BOV on..</TD></TR></TABLE>
How can you see the other side of the flange through the bov to determine this?
