URGENT HELP NEEDED IN PAD INSTALL!!!!!!! PLZ REPLY
Old Jan 26, 2006 | 08:03 PM
RGoose18's Avatar
Default URGENT HELP NEEDED IN PAD INSTALL!!!!!!! PLZ REPLY
I've been doing this install for a long long time and I cannot for the life of me get the rear caliper piston to screw in. I'm turning clockwise and have the master cylinder cap off, it moves, but not to the point where it goes into the boot, there's still about 1/4" exposed and I cant get the caliper over the new OEM pads. Please if you have any ideas post em quick
Old Jan 26, 2006 | 08:11 PM
KayOs's Avatar
Default Re: URGENT HELP NEEDED IN PAD INSTALL!!!!!!! PLZ REPLY (RGoose18)
https://honda-tech.com/zerothread?id=157444
Old Jan 26, 2006 | 08:39 PM
MugenHonda's Avatar
From: With my POS D15B2, Whereever whenever, United States
Default Re: URGENT HELP NEEDED IN PAD INSTALL!!!!!!! PLZ REPLY (KayOs)
hondas should turn in easily, meaning you should turn and push the rear caliper in.
However, if you can't then get the special tool from autozone which you can loan.
if that doesn't work, your caliper is seized, just make sure to pull the hand brake
Old Jan 26, 2006 | 08:49 PM
Batoutahell's Avatar
Try opening the bleed valve at that caliper, and push in while you turn the piston clockwise.
Old Jan 27, 2006 | 07:40 AM
Sehc Tib Alli Zerif!!!!!'s Avatar
cool guy name
Default Re: URGENT HELP NEEDED IN PAD INSTALL!!!!!!! PLZ REPLY (Batoutahell)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MugenHonda &raquo;</TD></TR><TR><TD CLASS="quote">hondas should turn in easily, meaning you should turn and push the rear caliper in.
Could you explain please?
Old Jan 27, 2006 | 11:29 AM
Black R's Avatar
25 Year Member
Default Re: URGENT HELP NEEDED IN PAD INSTALL!!!!!!! PLZ REPLY (walker111)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by walker111 &raquo;</TD></TR><TR><TD CLASS="quote">
Could you explain please?</TD></TR></TABLE>
Don't listen to him.
I think he meant to say "make sure the e-brake is down!"
Old Jan 27, 2006 | 11:38 AM
cool guy name
Default Re: URGENT HELP NEEDED IN PAD INSTALL!!!!!!! PLZ REPLY (Black R)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Black R &raquo;</TD></TR><TR><TD CLASS="quote">
I think he meant to say "make sure the e-brake is down!"</TD></TR></TABLE>
Thats what I thought, just wanted to know if I did things differently.
Morasso
Mar 20, 2008 05:12 PM
PJJ
May 13, 2007 01:01 PM
ylfotevoli
Nov 5, 2006 12:13 PM
Benjithx
14
Jul 22, 2005 06:47 AM
Cseika02
May 8, 2003 03:52 AM
