88 hf doors to 90 dx body
Old Jan 26, 2006 | 07:22 PM
xisda1's Avatar
Default 88 hf doors to 90 dx body
I got the 88hf for parts was planning on using the doors cause mine are f'ed up plus those doors weigh alot less. However their are no seatbelts on those doors. can I mount the seat belts on the pillars in my dx? is this possible has anyone ever done so? Will the doors even fit on my car?
Old Jan 26, 2006 | 07:27 PM
xisda1's Avatar
Default Re: 88 hf doors to 90 dx body (xisda1)
bizzzump
Old Jan 26, 2006 | 09:01 PM
VtecSyndrome's Avatar
You gotta search because this has been covered for sure, it can be done but you need to be able to weld (3 total holes I think?)
ludwig van's Avatar
i think that you should be ok as far as the seatbelt thing but the moldings are diff. correct me if im wrong it might just be the hatches that are like this.
Old Jan 26, 2006 | 09:26 PM
Default Re: 88 hf doors to 90 dx body (carsforearthworms)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by carsforearthworms &raquo;</TD></TR><TR><TD CLASS="quote">i think that you should be ok as far as the seatbelt thing but the moldings are diff. correct me if im wrong it might just be the hatches that are like this.</TD></TR></TABLE>
Pretty sure the REX is the same
Old Jan 27, 2006 | 12:14 AM
bag's Avatar
bag
Default Re: 88 hf doors to 90 dx body (VtecSyndrome)
WONT FIT.... 88 CRX DOOR FRAME(INCLUDIN SUM 89'S WIT PILAR MOUNT SEETBELT) IS DIFERNT DEN DA REST 89-91 CRX DOOR FRAME...
Old Jan 27, 2006 | 07:43 AM
rsca_crx's Avatar
Default Re: 88 hf doors to 90 dx body (BRIJPURT13B)
they're different. they're easy to switch.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BRIJPURT13B &raquo;</TD></TR><TR><TD CLASS="quote">WONT FIT.... 88 CRX DOOR FRAME(INCLUDIN SUM 89'S WIT PILAR MOUNT SEETBELT) IS DIFERNT DEN DA REST 89-91 CRX DOOR FRAME...</TD></TR></TABLE>
huh- no ****? you better tell my car, because it didn't seem to notice. i'll leave the screaming incoherent misinformation critique for someone else.
88 (and 89hf) doors fit on all years. 89dx/si and 90-91 doors only fit those cars.
thread on the doors-
https://honda-tech.com/zerothread?id=1498736
https://honda-tech.com/zerothread?id=1398846
seatbelt relocation-
it isn't bolt on (maybe a big fender washer in the existing hole if you got creative) but it isn't really that complicated either.
https://honda-tech.com/zerothread?id=1456104
88SeeOurEx
Dec 3, 2009 02:29 PM
shanghaining
15
Jun 28, 2006 09:22 PM
takeheed
Jul 13, 2003 06:19 AM
equalizir
10
Jun 21, 2003 05:28 PM
Steve91
11
May 21, 2002 05:40 PM
