pin out question
Old Jan 26, 2006 | 07:06 PM
matthevelli's Avatar
Default pin out question
have a 95 civic cx...need to do some wiring for the ecu
A7/A8 i beleive its for FLR1 and FLR2....question what does that stand for
A23/A24 those are for PG1 and PG2 again what does that mean
A25 =IGP1 ?
B1=IGP2 ?
and finally B9= STS ?
if someone could let me know. i'd appreciate it..i did a lot of searching and i couldnt find anything that explained those intials
Old Jan 26, 2006 | 07:26 PM
j12ball's Avatar
Default Re: pin out question (matthevelli)
A7=A8 fuel pump
A23/A24 = ground
A25=to main relay and to gound for o Yel/blk, Battery positive from Main relay, Battery Voltage with KOEO
B1=to pin A25 Yel/Blk, Battery positive from Main relay, Battery Voltage with KOEO
B9=starter signal
This might help:https://honda-tech.com/zerothread?id=1171263
Old Jan 27, 2006 | 03:37 AM
Default Re: pin out question (j12ball)
am i going to be able to wire this right to the ecu......some of these wires burned up...and i need to either replace the whole harness or cut and splice
Old Jan 27, 2006 | 08:20 PM
bump
Old Jan 29, 2006 | 04:16 AM
someone...i dont want to mess this up..
Old Jan 29, 2006 | 10:12 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by matthevelli &raquo;</TD></TR><TR><TD CLASS="quote">am i going to be able to wire this right to the ecu......some of these wires burned up...and i need to either replace the whole harness or cut and splice
someone...i dont want to mess this up..</TD></TR></TABLE>
Old Jan 29, 2006 | 10:22 AM
the reason i ask this.. i need to replace the main relay plug and wires taht goes to the relay cause of a small lil fire...i was giogn to replace the whole harness..but i figured why not just feed the wires too the ecu..and be done..so i bought a used harness..and cut the main relay harness away from the rest...i looked at my harnesss (95 cx) and i believe it has 11 or more wires.. the <U>used harness </U>wich is from a 93 ex civic only had like 7 wires.. i need to know if i can use this ex main relay harness? i dont want to wire this all up..and be missing stuff..
Old Jan 29, 2006 | 04:59 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by matthevelli &raquo;</TD></TR><TR><TD CLASS="quote">the reason i ask this.. i need to replace the main relay plug and wires taht goes to the relay cause of a small lil fire...i was giogn to replace the whole harness..but i figured why not just feed the wires too the ecu..and be done..so i bought a used harness..and cut the main relay harness away from the rest...i looked at my harnesss (95 cx) and i believe it has 11 or more wires.. the <U>used harness </U>wich is from a 93 ex civic only had like 7 wires.. i need to know if i can use this ex main relay harness? i dont want to wire this all up..and be missing stuff..</TD></TR></TABLE>
boostlsveg
Jul 25, 2014 06:25 PM
Taylorej1-93
14
Jan 29, 2013 08:02 PM
b20acura
Jul 30, 2007 09:43 PM
hatchback_al
Oct 26, 2004 10:00 AM
JDMflavor_EJ
May 25, 2004 10:18 AM
