ANTI SQUEEL ON REAR PADS?????
Old Jan 26, 2006 | 06:53 PM
RGoose18's Avatar
Default ANTI SQUEEL ON REAR PADS?????
Quick question,
how neccessary is the anti squeel on the rear pads. I'm in the process of changing them out and honda supplied it w/ the new pads. Don't really want to get into it if I dont have to, it's like 4 degrees out and I'd rather not be playing w/ lube in the arctic . Thx
Old Jan 26, 2006 | 07:31 PM
tuan...'s Avatar
its only for your convience. If you keep an eye on the wear, then you dont really need it.
Old Jan 26, 2006 | 07:54 PM
Jowee's Avatar
Default Re: (RRa_kcaLb)
Might as well put some on while you're already there. Does it not come in a bottle where you just squeeze a dab on the back of the pad?
Old Jan 26, 2006 | 08:00 PM
KayOs's Avatar
Default Re: (Jowee 1162)
it comes in pre packaged small clear envelopes if OEM.
I wouldn't worry if you don't use anti-squeal....
Old Jan 27, 2006 | 04:43 AM
Reid's Avatar
Global Moderator
Anti squeal is not needed at all. I just changed the rear pads out and did not use any.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RRa_kcaLb &raquo;</TD></TR><TR><TD CLASS="quote">its only for your convience. If you keep an eye on the wear, then you dont really need it.</TD></TR></TABLE>
What does anti squeal have to do with pad wear?
Old Jan 27, 2006 | 05:26 AM
tuan...'s Avatar
Default Re: (Reid)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Reid &raquo;</TD></TR><TR><TD CLASS="quote">Anti squeal is not needed at all. I just changed the rear pads out and did not use any.
What does anti squeal have to do with pad wear?</TD></TR></TABLE>
i thought he was talkin about hte metal indicators for some reason...
Old Jan 27, 2006 | 05:55 AM
andyt's Avatar
Default Re: ANTI SQUEEL ON REAR PADS????? (RGoose18)
I look at it like this:
If you don't use it, and then they squeal, will you take it back apart and put the lube on?
If so, just put it on to begin with
Old Jan 27, 2006 | 08:29 AM
RGoose18's Avatar
Default Re: ANTI SQUEEL ON REAR PADS????? (andyt)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by andyt &raquo;</TD></TR><TR><TD CLASS="quote">I look at it like this:
If so, just put it on to begin with </TD></TR></TABLE>
Good point, but it's a pain in the *** because the stuff gets everywhere. Next time I won't be using any anti squeal on the rear pads
Old Jan 27, 2006 | 09:00 AM
JjuuN R's Avatar
Default Re: (Reid)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Reid &raquo;</TD></TR><TR><TD CLASS="quote">What does anti squeal have to do with pad wear?</TD></TR></TABLE>
i don't think he meant it like that, i think what he meant was to keep an eye on the pad wear and change them when needed so you don't have to worry about squeeking or squealing from them.
Old Jan 27, 2006 | 10:32 AM
Jowee's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RGoose18 &raquo;</TD></TR><TR><TD CLASS="quote">
Good point, but it's a pain in the *** because the stuff gets everywhere. Next time I won't be using any anti squeal on the rear pads</TD></TR></TABLE>
If you just cut the corner of the package then squeeze it out in a uniform line, it's easier than tearing it open then trying to control it. Better yet, go to Auto Zone a pick up a bottle of the red stuff that's easy as pie to apply.
essex
10
Jul 8, 2008 03:00 AM
PatrickGSR94
Sep 14, 2005 05:02 PM
Flux
Jun 8, 2005 03:47 PM
bb6h22a
Mar 14, 2005 11:49 AM
ebelp
May 3, 2004 09:58 AM
