For those with ex big brakes, a question for you (not typical)
I have owned 2 CRX in the past (one is a 90 DX and the current one is 88 SI)and I have done a ex brake swap on both of them. After the swap was completed, my gas mileage dropped a ton, before the swap I could get around 36-38mpg, but rite now, I am only getting 24-26mpg.
I dont know why, but does it have to do with the bigger brakes and heavier spindles? I replaced alll my plugs after I realized the situation but that doesnt help at all. Any ideas?
Thanks in advance.
Steve
Thanks in advance.
Steve
From: I told you to wait in the truck in Texas, United States
I would first suspect the hub bearings or maybe "stuck" brake calipers...
If a change to the hub/brake assembly dropped the gas mileage,
There must be a "rolling-resistance" created by some sort of drag..
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 88DXCRX »</TD></TR><TR><TD CLASS="quote">I would first suspect the hub bearings or maybe "stuck" brake calipers...
There must be a "rolling-resistance" created by some sort of drag..</TD></TR></TABLE>
right on the money
right on the money
there's nothing draging at all. I raised the car on the lift and try to feel any looseness or draging, but there's nothing. Yes, it happened on both of them.
WHY???
WHY???
i have the same problem
mine seem to be on the whole time, and everytime i cut the car off, the pedal gets stiff again when it should have play still in, also even in neutral w. the ebrake down the car does not roll, and its a crx i use to be able to push it w. one hand newhere i needed it to go, any help would be great
Your gas mileage will drop because larger diameter brakes require more power to put them into motion. If you put a car on a dyno with small discs and then put it back on the dyno with large brake discs, you can lose 4-8 horsepower from what I have seen.
Because it takes more throttle to now put the car in motion at the same rate it used to accelerate, you see a drop in gas mileage. Its the same thing as underinflated tires causing bad mileage.
ya but the drop in mileage would not be noticeable. Something is wrong, maybe the bearings have a lot of play that you won't notice while the car is jacked up.
what is meant by bearings having play in them? i need to get my brake problem resolved as soon as possible, im going threw tires and pads liek a champ, is it possible to install a booster wrong?
Did you touch the brake booster at all when you did the EX swap?
Check for a improperly adjusted pushrod if so.
I had a brake problem that plagued me for weeks before I finally figured it out.
The pushrod was just far enough forward that when the car was 'on' and created vacuum it caused pressure in the brake system.
This sort of drag will NOT be noticeable by just putting your car up on a lift!
Hi I have a 85 crx (old i know but good on gas) that i bought off ebag, well it just about had no brakes i mean pedal to the floor and i put a reman master cylinderon it and the brakes are still sucko could this boster adjustment help my brake problem?thanks Stephen ps how and where do I adjust it?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by red85x »</TD></TR><TR><TD CLASS="quote">Hi I have a 85 crx (old i know but good on gas) that i bought off ebag, well it just about had no brakes i mean pedal to the floor and i put a reman master cylinderon it and the brakes are still sucko could this boster adjustment help my brake problem?thanks Stephen ps how and where do I adjust it?</TD></TR></TABLE>
I dont think so, check/adjust you rears and blead all 4
BEYAAAH
Aug 15, 2007 11:44 AM
Nevaeh
12
Dec 9, 2004 09:09 PM
hatchinprogress
13
Nov 18, 2004 03:36 PM
