87 si fuel problems
Old Jan 26, 2006 | 04:13 PM
Xenobi's Avatar
Default 87 si fuel problems
Ok today I replaced the fuel pump (because it wasn't kicking on, and starving my car for fuel, which was causing it to die). Pump turns on now, but when I start the car, its still not getting fuel. Car will slowly die when I push start it, because it isn't getting fuel.
Only thing I can think that may be causing it is the fuel filter. Any other ideas?
Old Jan 26, 2006 | 04:23 PM
mrsuburban's Avatar
Default Re: 87 si fuel problems (Xenobi)
Change the filter and see what happens. Thier like 10 dollars.
You put a replacement maxi pad on the pump?
Sounds like a bad connection though. Make a hole in the rex and inspect.
Old Jan 26, 2006 | 04:29 PM
Xenobi's Avatar
By replacement maxi pad, do you mean that little screen thing in the end of the fuel line from the tank?
No, I didn't. Looked pretty fine to me....but yeah. I went to autozone to buy a fuel filter for it, and the one they told me it was is completely diffrent.....and I didn't have time to dig for it. So tomorrow I'm going to disconnect the filter completely, turn the key, and see if fuel is even getting to the filter. If it is, then I'll know what my problem is......
Old Jan 26, 2006 | 09:24 PM
DEIVIONCRX's Avatar
Default Re: (Xenobi)
just have them take the book out to your car and find one that works
id replace the filter first, and then look at the main relay and see if it needs to be resoldered
Uncle Ben's
May 25, 2021 03:58 PM
SlowB20z
Apr 28, 2013 07:26 PM
hermtm2
23
Apr 8, 2009 06:17 PM
islnder102
Sep 26, 2006 01:08 PM
crnimacak
Apr 21, 2006 10:11 PM
