GSR Block, ITR Pistons?
Old Jan 26, 2006 | 01:53 PM
batmang yO!
Guest
Posts: n/a
Default GSR Block, ITR Pistons?
I've searched and only found partial answers. Im looking to get a set of ITR pistons for my b18c1, and I also have a set of ITB's off of a GSXR 750 that im gonna have installed, basicly what im trying to find out is, given those two mods alone, would I need or benifit by getting larger injectors? I do understand that I will need tuning, I do have a vafcII but I also understand that it isn't gonna do. In which case what would you recomend I use to properly tune it with... chipped ecu? hondata? ...and what not... And what kind of gains (roughtly) should I expect?
Thanks...
Old Jan 26, 2006 | 02:00 PM
WhoDoYouThink's Avatar
Default Re: GSR Block, ITR Pistons? (Beavis)
yes you will want larger injectors. i would say 310cc should be suffice for that setup. i would highly recommend looking into some more aggressive cams as well to help the motor work better with the ITBs
Old Jan 26, 2006 | 05:52 PM
batmang yO!
Guest
Posts: n/a
bump
Old Feb 5, 2006 | 08:51 AM
dc2gsr96's Avatar
Default Re: GSR Block, ITR Pistons? (2000turbogsr)
so putting itr pistons in a gsr block u need bigger injectors??
Old Feb 5, 2006 | 09:34 AM
blkb18's Avatar
Default Re: GSR Block, ITR Pistons? (dc2gsr96)
pistons alone, no. I am pretty sure itr and gsr injectors are the same. But with itb's i would say yes.
Old Feb 5, 2006 | 11:59 AM
b16crx88's Avatar
have personally done something like that gsr block with ls crank and jdm itr pistions... it sucked waste of time and money. just my .02
Old Feb 5, 2006 | 12:59 PM
EK FLY's Avatar
Default Re: (b16crx88)
well considering that it would bump ur compression like around 11.4 or something .. would make some power if u really want to get some raw power u could add a set of nice cams
Old Feb 5, 2006 | 08:29 PM
enil01's Avatar
Default Re: (EGSR)
https://honda-tech.com/zerothread?id=947432
Might help answer some injector questions.
gsr96cx
Nov 17, 2007 07:45 PM
wreckeddc4
Aug 20, 2007 09:30 AM
JDM_EK4_Coupe
Jun 27, 2007 08:42 PM
batmang yO!
Jan 27, 2006 10:55 PM
dsosa51
May 24, 2004 10:10 PM
