B18C Into 99 Si Civic - Evap Quick Question !
Old Jan 26, 2006 | 01:14 PM
Problemo's Avatar
Default B18C Into 99 Si Civic - Evap Quick Question !
Hi folks,
I have been stumbling around my engine bay and found a plug which looks like it should goto the EVAP solenoid (Yellow/black , Red) but is just hanging loose in my engine bay.
I used to have a B16 and now have a B18C as far as I can tell the purge can is still the original Si item. My question goes where does the plug go ? A picture or a good explanation would be great.
Thanks folks,
- Prob
Old Jun 27, 2006 | 10:53 PM
Civic168's Avatar
Default Re: B18C Into 99 Si Civic - Evap Quick Question ! (Problemo)
ive got the same problem.. eheheh how did u resolve it?
Old Jun 28, 2006 | 07:52 AM
94eg!'s Avatar
#1 Super Guy
Loved
Default Re: B18C Into 99 Si Civic - Evap Quick Question ! (Civic168)
The plug is for the EVAP purge solenoid. When I installed my JDM B18C in my EG, I grabed the EVAP solenoid off my D-series intake manifold & hooked it up just like my OEM system (your EK could have the solenoid on the firewall). If you have the Helms manual for your car, it has a detailed description of the EVAP system & how to hook it up properly. Basically there is a #7 vacuum hose that goes from a nipple on the intake manifold to one of the nipples on the EVAP solenoid. Then a second vacuum line going from the solenoid to the EVAP canister....
Since my JDM manifold didn't have anywhere to bolt the D-series solenoid onto, I just ran the vacuum lines & zip tied the solenoid to the engine harness underneath the intake manifold (out of sight)...
I hope this helps
hondarules7
Jul 2, 2024 07:58 PM
fireballz
Feb 5, 2011 09:50 AM
akteamster
21
Nov 26, 2005 01:27 PM
integra6650
Mar 13, 2003 07:36 AM
