wheels help
i have some wide axia 15" rims on my car and i have a camber that makes the inner part of my tires to wear out what shoyuld i do should i change the wheels back to stock or should i raise my suspension, camber kits are not available in this part of the world nigeria africa or is there a way for me to adjust this problem, i did'nt drop my suspension prior to this please i need help
offset=-0.75 +or- 0.2
7,5x15 rim with a high offset can indeed cause rubbing on the inside of the wheel panel.
Why use 7,5 wide rims when 6x15 , 6,5x15 can carry 195 tires very good?
Try and find the offset, here's what you can do from cheaper to expensive:
1. remove wheelpanels (not recommended)
2. use wheelspacers (not recommended)
3. buy different rims with the correct size/offset
SIC_jdm_da9
Nov 9, 2008 07:33 PM
civboy115
17
Mar 16, 2004 02:03 PM
comptechgsr
Jun 15, 2002 10:20 PM
