96(obd2)b18b into a 95 LS chassis
I've done a bit of searching on the topic of the swap,
not really a swap but a engine replacement but anyways.
Pretty much from what I've read, it'll drop right in,
Only thing I wasn't quite sure on was the distributor.
I'll have an obd2 & obd1 dizzy, so either way that should work out,
But will it matter which one I use on the newer engine?
Is there anything else I should pay attention to with it,
Or will it be just like I'm putting in the same engine, without any modification?
I also have the obd1 ecu/harness, being it is a 95 ls.
Nisif
Oct 20, 2012 06:11 PM
TURBOED-TEG
Sep 17, 2002 05:05 AM
