3rd gear pull
hey guys...i did a little searching for more torque and basically found that we dont have any...n/a. but my question is...i dynoed my car at 192 whp and i only have 148 torque....does that seem right? i did it on a 3rd gear pull...and someone said it would be lower at a 3rd gear pull..why is that? Thanks. Oh...I NEED MORE TORQUE!!!!!
Mods:
type s piston
skunk2 im
catback exhaust
p28 chipped/tuned
jun stage3 cams
i/h
vafc(basically just to look at now)
Mods:
type s piston
skunk2 im
catback exhaust
p28 chipped/tuned
jun stage3 cams
i/h
You should have done it in 4th gear. It would have been more accurate of what your motor's really putting out. You have good compression? Clean injectors? Good fuel filter? Plugs? Wires? Cap? Rotor? All the little things can really cost you some power if you forget about them. And did you install your own cams? If you did, what did you torque them to? I over torqued mine at first (should have been 7, they were at 15) and I lost a noticeable amount of power
well...i just changed the spark plugs and oil...but i think i had to replace some fuel injectors a couple of months after...they could've been going bad...and i've just got some dc headers and either 2.25 or 2.5 all the way through the exhaust...thanks for the replies...appreciate it...any more would be helpful....oh and the best time so far is a 14.6 in the quarter...i prolly need to go back and try the 4th gear pull and track again...
i dont get it either...but i've only dynoed it once and ran it at the track with those setups once also....so....could be me at the track...but dont know about the dyno....#'s not what i expected...
dangit not with is making my sad cause im building my motor right now with type s pistons and i was hoping for 200whp. but mine are .25 OS. but im also only running stock cams and a stock header for right now till i get more cash money YOU KNOWW!
yea...better headers would be great but $500+ im gonna have to save for em...i'tll be awhile...so does anyone know why a 4th gear pull on the dyno would be better???
EJ1 wilcox
Apr 30, 2007 12:22 PM
cr-x si
Nov 20, 2002 07:17 PM
