No brakes after swap... Booster or Master cylinder?
Old Jan 25, 2006 | 08:50 PM
Khmi's Avatar
Default No brakes after swap... Booster or Master cylinder?
Before my z6 swap my brakes were fine. Now after swap when driving the i have no brake pressure. But when the car is off the pedal is stiff as hell, I press it as hard as i can, dosent go down. But right when the car is started brake pedal pressure goes to ****, have to pump breaks to stop. Is this a booster or MC problem? I bleed the breaks too.
Old Jan 25, 2006 | 09:05 PM
cr-x-91's Avatar
DID U BLEED THEM THE PROPER WAY? sorry bout the caps lock. make sure u got all the lines ran right.
Old Jan 25, 2006 | 09:28 PM
Khmi's Avatar
Default Re: No brakes after swap... Booster or Master cylinder? (Khmi)
I have bleed brakes before, I pump the brakes while my friend opens and closes the bleeder valve on each tire starting with the rear passenger 1st, then driver front, read driver, lastly front passenger.
I just wondering if it could be the booster beacuse pedal goest straight to the ground when the car is started.
Old Jan 25, 2006 | 09:38 PM
downest's Avatar
What did you swap? Just bleed them again, never can do it too much. Use a vacuum pump.
Old Jan 25, 2006 | 09:41 PM
Khmi's Avatar
Default Re: No brakes after swap... Booster or Master cylinder? (downest)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by downest &raquo;</TD></TR><TR><TD CLASS="quote">What did you swap? Just bleed them again, never can do it too much. Use a vacuum pump.</TD></TR></TABLE>
D16z6 swap
Old Jan 26, 2006 | 12:14 AM
downest's Avatar
So did you even touch the brakes? Just bled them and now they suck? Weird. Like I said, get a vacuum pump and a couple of litres of fluid and just bleed the **** out of them, make sure you aren't leaking. If you're sure they're done right, might be time to get a new master cylinder. Someone on the resource posted a while back about how our MCs start to leak when the brakes are bled. His idea (not verified though) was that the cylinder is normally pressed to a certain distance in the bore on the MC, and when you bleed it and go further down, you break seals or something. Anyway, can't hurt to replace it, get a 15/16".
Old Jan 26, 2006 | 09:06 AM
civic889802's Avatar
i have the same problem still havent fix it haha i think is master cylinder when is time to sto brake peadal goes all the way in. i even took it to a shop just to make shure they dint even know what was wrong but i will replace the master cylinder n let u know if worked
Old Jan 26, 2006 | 09:19 AM
Khmi's Avatar
Default Re: No brakes after swap... Booster or Master cylinder? (civic889802)
Yeah can't be bad to replace my MC, i have an extra 1" master cylinder from my spare parts EF, its prettey new too.
Old Jan 26, 2006 | 09:27 AM
gsxr1k05's Avatar
its more than likely the master cyclinder. i had a 93 buick lesabre that had the same problem. replaced the master cyclinder after checking with the buick shop manual i had said that was the problem. fixed it.
as for bleeding, i thought it was always passenger rear, driver rear, pass front, then driver front..
if i am wrong bout the bleeding let me know.. is it a universal thing, or a honda thing
Old Jan 26, 2006 | 09:36 AM
Khmi's Avatar
Default Re: No brakes after swap... Booster or Master cylinder? (gsxr1k05)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by gsxr1k05 &raquo;</TD></TR><TR><TD CLASS="quote">
if i am wrong bout the bleeding let me know.. is it a universal thing, or a honda thing</TD></TR></TABLE>
Thats the way i did it until i took a look at a Helms Manual (always thought you had to do the farther wheel first). guess i was wrong.
Old Jan 26, 2006 | 09:51 AM
downest's Avatar
Honestly, I think everyone does it different. My dad taught me farthest to nearest, but the manual says otherwise, and I think the Haynes manual differs from the OEM too. Anyway, make sure you bench bleed that 1" when you put it on, or you're going to spend a few hours trying to get all the fluid out. What is that MC from?
Old Jan 26, 2006 | 10:07 AM
rsca_crx's Avatar
vac lines hooked up?
Old Jan 26, 2006 | 10:09 AM
SLR ef9's Avatar
Default Re: No brakes after swap... Booster or Master cylinder? (rsca_crx)
i just did ls swap same thing happened got a new master cylinder and bleed the brakes now it works fine. like you before the swap i did'nt have a problem.
Old Jan 26, 2006 | 10:30 AM
Donkey85's Avatar
Default Re: No brakes after swap... Booster or Master cylinder? (SLR ef9)
are you 100% sure you reconnected the vac line to the booster. i know its a stupid question but sometimes we all then to over look the obvious.
Old Jan 26, 2006 | 10:55 AM
crx_88_si's Avatar
Default Re: No brakes after swap... Booster or Master cylinder? (Donkey85)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Donkey85 &raquo;</TD></TR><TR><TD CLASS="quote">are you 100% sure you reconnected the vac line to the booster. i know its a stupid question but sometimes we all then to over look the obvious.</TD></TR></TABLE>
and if you messed with that vac line did you break the valve or put it in backwards?
1sikhatch
Dec 7, 2009 04:18 AM
rollie_jimenez ef9
10
Nov 4, 2007 02:15 PM
Cyber ITR
Jul 20, 2007 11:04 PM
Filliam H. Muffman
14
Aug 2, 2004 06:24 PM
