In the middle of B16a swap in 1990 CRX Si (need help)
on the back of my 1990 Si Throttle body, there is some sort of censor hooked up to the back of the manifold. it's got a vaccumm hose leading to it, but i'm not sure if it's vaccumm or not. On my b16a manifold, i don't have one. this means i have an extra plug just sitting there. is this ok? anyone know what this is? i haven't been able to find out. description:
looks to be a solenoid of some sort.
silver on top, with black on the bottom.
it's on the back, driverside of the intake manifold.
there seems to be a little oil residue on the inside, too.
it's a white, 2 wire plug.
any help appreciated. thanks.
I had the same thing on my B18b...Im not sure if its the same, but what i did was cut the goofy looking white plug, cut off the plug that went on the B18 (which is a 2 wire also) and then just spliced my SI wires to the B18b plug, one of the wires will have a black stripe, those should match up (your ground). Ill send you a picture later today...
-Jake
-Jake
i believe you don't have that sensor on the B16a and ZC just let the plug hang there! iSoit's not ued whe running B16a or ZC! it's a solenoid looking deal on the drivers side of the intake manifold ?
yeah, found out it isn't used. but, thanks. now i need help pulling the stupid ECU pins. motor is in. looks awesome. can't wait.
92d15b7
Mar 30, 2011 07:02 AM
Beyond Imagination
Jun 18, 2004 07:10 PM
