i got d16y7
my friend saved me and sold me his d16y7 today for 20 bucks. now for the question... what all needs to be done to swap this in currently i have the d15 4 speed dual point motor in it. also im wondering what ecu i should use. i have a PM6 from my last SI would that work good or would it run like ****? Also is there a place i can just buy the conversion harness for dpfi to mpfi? thanks
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ef9typer »</TD></TR><TR><TD CLASS="quote">my friend saved me and sold me his d16y7 today for 20 bucks. now for the question... what all needs to be done to swap this in currently i have the d15 4 speed dual point motor in it. also im wondering what ecu i should use. i have a PM6 from my last SI would that work good or would it run like ****? Also is there a place i can just buy the conversion harness for dpfi to mpfi? thanks</TD></TR></TABLE>
It's just two wires. Can't be taht bad.
In order to stay obd-0 I believe the distributor needs to be swapped over. There's more but I have no idea.
u need to convert from dpfi to mpfi
the si ecu will work fine...
also get your hands on a SI manifold and bolt that up to the new motor the y7's manifold will work, but ur going to have fitv issues along with iacv and air temp sensor, so go with an si intake manifold..
If you don't mind staying with the DPFI, the swap is really easy:
http://www.ef-honda.com/main/v...=dpfi
can i use the si ecu with dual point or no???? i plugged it into the d15 and it ran like crap. wondering how it will do with d16
si ecu will work, but like they have said before you need to swap to mpfi.
so this is what you will need besides the ecu you already have:
-88-91 si manifold w/ tb and injectors, fuel rail and sensors - basically a COMPLETE si manifold
-88-91 si distributor
-dpfi to mpfi conversion harness - http://www.rywire.com sells one, ebay, and other people on here as well. not that difficult to do.
-also, i would get a 5 speed tranny, si is best but dx ain't that bad.
you can use your stock manifold for now
just search around, you can get most these parts for cheap, ebay can be your friend for something like this. my old mpfi swap cost me less than a $100. u pull it yards are great too.
good luck
good luck
i got a 5 spd tranny on the d16y7 i got
all for 20 bucks form a friend of mine. just need to get the other parts i am doing the swap on wednesday wish me luck
well to get the y7 tranny to work you will need a cable to hydro conversion.
the 88-91 civic trannies are cable operated, while 92+ trannies are hydro. password jdm has one kit from innovative for $150..
that is the only way to keep that tranny, that is why i told you to try and find the 88-91 civic si or dx tranny to upgrade from your 4 spd.
post back up on here if you need some more help
i have a stock 91 CRX HF
would this work for me?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hb_guy »</TD></TR><TR><TD CLASS="quote">si ecu will work, but like they have said before you need to swap to mpfi.
good luck
good luck
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ef9typer »</TD></TR><TR><TD CLASS="quote">do u know the exact link cuz i def need it i looked at pwjdm site and could not find.</TD></TR></TABLE>
http://www.passwordjdm.com/pro...D=431
Its a conversion to allow your cable clutch to actuate the clutch fork on a hydraulic tranny, but you'd still need to fab a motor mount for the passenger frame rail mount. I'm not 100% sure if the rear crossmember mount will bolt up to the hydraulic tranny or not, and you may be fabing a front mount.
You'd certainly save alot of time and effort buying that Innovative part though.
del_soldier93
Feb 11, 2010 04:24 AM
kens89ef
Jun 20, 2005 03:02 AM
J.P.
Mar 26, 2003 06:08 PM
