Its a bad day for wiseco!!
Old Jan 25, 2006 | 06:42 PM
AccordEX-T's Avatar
Default Its a bad day for wiseco!!
HAS ANYONE SEEN THIS BEFORE TO WISECO PISTONS.
I ONLY RAN THESE FOR 5 MOUNTHS
Modified by AccordEX-T at 7:53 PM 1/25/2006
Old Jan 25, 2006 | 06:49 PM
rhdune16's Avatar
DAMN how did that happen... detonation or non-effecient turbo w/ too much hot air... that sucks bro...
if you wanna get rids of the rods.. let me know cause you have a buyer
Old Jan 25, 2006 | 06:55 PM
Ross 2.0's Avatar
In a Junkyard near you.
holy crap... let me know next time your going to do that and i'll bring some hotdogs and we can make smoores too!
Old Jan 25, 2006 | 07:01 PM
P_Adams's Avatar
Default Re: Its a bad day for wiseco!! (AccordEX-T)
I'm curious, did you find all the ring gaps lines up; or were they staggered? I'm tring to fathom why you suffered a thermal event on one side of the piston crown.
Detonation usually shows up very close to the spark plug (centered between the valve reliefs)
P
Old Jan 25, 2006 | 07:07 PM
AccordEX-T's Avatar
Default Re: Its a bad day for wiseco!! (P_Adams)
YES THEY WERE LINED UP WHEN I PUT THEM IN
Old Jan 25, 2006 | 07:14 PM
Ross 2.0's Avatar
ouch.. the burnup is on you then...
Old Jan 25, 2006 | 07:21 PM
P_Adams's Avatar
'cuz they're not supposed to be. They're supposed to be positioned 120 d from each other.
ie: 4 o'clock, 8 o'clock and 12 o'clock when viewed from the top.
P
Old Jan 25, 2006 | 11:36 PM
raceACCORDingly's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by AccordEX-T &raquo;</TD></TR><TR><TD CLASS="quote">
inline fuel pump and fmu
was it atleast tuned?
Old Jan 26, 2006 | 05:01 AM
YeuEmMaiMai's Avatar
that's one expensive lesson learned there........all piston rings are to be staggered
Old Jan 26, 2006 | 05:24 AM
USDM EG's Avatar
Default Re: (YeuEmMaiMai)
hmm, nick...
1...STOP YELLING!! No caps!
2...When ur car is done, its going straigh to the dyno...
BTW everyone...he had DSM's, VAFC, and inline pump... no tuning really, and yes it detonated like hell...
But, after this rebuild, everything is being redone...so dont worry, everything will be perfect!
Modified by USDM EG at 8:43 AM 1/26/2006
Old Jan 26, 2006 | 05:54 AM
P_Adams's Avatar
Default Re: (USDM EG)
Hey, if it's any consollation; he got bit by something that is all too often overlooked by instructors in Technical Schools. And in all fairness it probably wouldn't have been an issue if it had not been boosted. Now he knows; an expensive lesson for sure. But I'm quite sure he won't forget it for a LONG time
P
Old Jan 26, 2006 | 05:58 AM
notoriousB's Avatar
sorry buddy but this is NOT Weisco's problem. It is yours.
Get some real fuel management and **** like this wouldn't happen. It's called tuning. Look into it with a solution that can control your ignition timing.
looks like an expensive lesson to learn.
Old Jan 26, 2006 | 07:10 AM
b_ron007's Avatar
dang dog, you didn't do much research when you did ur build. u were running the AFC hack?
how much boost were you running?
timing and fueling was the BIG PROBLEM!
Old Jan 26, 2006 | 08:01 AM
twkdCD595's Avatar
OUCH... that hurts man, thats why you have to make tuning a setup a priority. Next time, dont drive it till you get it tuned... keep some money set aside for just this reason.
How much boost was that at? Did you take any timing out at the dizzy to compensate for the vafc (guessing not)? What were your fuel settings at? What plugs? Etc?
rhdune16: I dont know why you would want those rods... they are just shot peen'd stockers from what I can tell. If you really want some rods, I just happen to have 2 full sets of eagle h beams sitting here (dont ask why I bought 2 sets, it was some good deals).
Old Jan 26, 2006 | 10:39 AM
fw190bvi's Avatar
Default Re: (twkdCD595)
well, thats what you get for doing things the wrong way.....
why on earth someone would spend money on internals, and then cheap out on tuning is against me...oh well, good luck next time
Fc_v8
Nov 19, 2009 12:12 PM
7speed
Sep 12, 2005 02:48 PM
paulzy
Mar 24, 2005 06:51 PM
Hoosier Daddy
Oct 2, 2003 02:21 AM
