220 Miles per tank, o2 sensors going out?
Old Jan 25, 2006 | 05:16 PM
SiR Inspired ED7's Avatar
Default 220 Miles per tank, o2 sensors going out?
Hey guys,'m doing 220 miles per tank, when i've seen people do better milage.
i currently have a 88 Crx Si with a jdm 1st gen b16a mated with a j1 tranny (short geared 80 mph in 5th at 4700 rpms pretty much stock obd 0 (pwo) 2 1/4 piping straight piping(no catylatic converter) to a magnaflow stock looking muffler. i have vafc II but i havnt messed with it, only with the vtec control, other than that nuttin else. i bought the car with the vafc II for those who are wondering why i have it on a bone stock car with no cams... now to the question,
Is it possible for the o2 sensors to go out without getting a check engine light?
any input is greatly appreciated
Modified by 88 Crx Si at 7:26 PM 1/25/2006
Old Jan 25, 2006 | 05:41 PM
dopey88's Avatar
Default Re: 220 Miles per tank, o2 sensors going out? (88 Crx Si)
I had this problem before with my 89 rex b16a. What was happening was I was not getting enough back pressure so my acceleration sucked/poor gas milage/no power try adding a resonator to your exaust system or replace the cat.
Old Jan 25, 2006 | 05:47 PM
Default Re: 220 Miles per tank, o2 sensors going out? (dopey88)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dopey88 &raquo;</TD></TR><TR><TD CLASS="quote">I had this problem before with my 89 rex b16a. What was happening was I was not getting enough back pressure so my acceleration sucked/poor gas milage/no power try adding a resonator to your exaust system or replace the cat. </TD></TR></TABLE>
can anyone else confirm this? I might be adding a cat since it's illegal not to run one, but than again i bought the car as it is
Old Jan 25, 2006 | 06:09 PM
red_EF9Si's Avatar
just replace them bitches. they're fairly cheap and will only help in the long run. Do them one by one so you dont accidentally cross them.
Old Jan 25, 2006 | 06:53 PM
white90crxhf's Avatar
when i saw i got 37mpg i thought something was wrong, lucky the check engine light came on soon after i filled up and it was the o2 sensor, then it was back to 50+
Old Jan 25, 2006 | 07:18 PM
slywfbpsi's Avatar
Default Re: (white90crxhf)
If you want a comparision. When I had my 00si, I would only get 180 a tank. When I added an aem cai, tanabe exhaust, msd sci, different plugs, and cam gears only then did it get up to 254 a tank with some tuning. if your o2 sensor was going bad your gas mileage would decrease but you would also have the tail-tail signs of a cel with an o2 sensor code that went away anytime you turned off the car.
Old Jan 25, 2006 | 07:25 PM
bagpipe goatee's Avatar
an o2 sensor has to be pretty far off to throw a CEL, as it just tells the computer what range it's in. when they start to go, the range is off, but it's still something it COULD be. it has to give an impossible value for the computer to throw a CEL.
yeah, replace it (them), it's cheap. probably not the only reason you have slightly poor mileage, but it definitely contributes.
Old Jan 25, 2006 | 08:58 PM
DocSean's Avatar
I always thought 02's were expensive. Anyone know a good RELIABLE supplier?
Old Jan 25, 2006 | 09:21 PM
EL Vap133's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by white90crxhf &raquo;</TD></TR><TR><TD CLASS="quote">when i saw i got 37mpg i thought something was wrong, lucky the check engine light came on soon after i filled up and it was the o2 sensor, then it was back to 50+ </TD></TR></TABLE>
Yeah right!
Old Jan 25, 2006 | 09:47 PM
bigcalidave's Avatar
Autozone. The o2 sensor on newer cars with the 4 wires (heated) is expensive, but the obd0 ones are dirt cheap, like $35
Old Jan 25, 2006 | 10:45 PM
Default Re: (bigcalidave)
anyone recommend any type of o2 sensors? i was looking at some that NGK makes...
Old Jan 26, 2006 | 01:36 AM
killa rex's Avatar
Default Re: (88 Crx Si)
Denso (if they make a 1-wire)
Bosch..ok
NGK..never knew they make one??
Old Jan 26, 2006 | 02:22 AM
slywfbpsi's Avatar
Default Re: (xmunxjai648)
Yeah, the Bosch universal 1-wire I put on my car, when my sensor went bad, was only $17 from Autozone.
Old Jan 26, 2006 | 04:21 PM
ngk is ntk for o2 sensors i think....
mrmanuke
Apr 1, 2006 08:18 AM
SiR Inspired ED7
Jan 30, 2006 08:00 AM
TheHatchHog
14
Mar 25, 2004 09:31 PM
Knightrider
Aug 8, 2001 01:09 PM
