ram manifold-flange on first-
Old Jan 25, 2006 | 02:06 PM
BEEYOND's Avatar
Default ram manifold-flange on first-
do you weld the head flange onto pipes first or weld all the pipping together and then lastly weld the pipe to the head flange...???
Old Jan 25, 2006 | 02:42 PM
discrete's Avatar
Just tack it then do whatever you want.
Old Jan 25, 2006 | 04:52 PM
AspectIndustries's Avatar
Default Re: (discrete)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by discrete &raquo;</TD></TR><TR><TD CLASS="quote">Just tack it then do whatever you want. </TD></TR></TABLE>
Wow, your being helpful.!
If your using BURNS collector, then you would tack them all together. Make sure fitment is nicely done, and the break off the welds at the head flange, and slide out from the burns collector, weld all 4 runners together, assembled, then lastly tack it onto the head flange, then weld whatever neccessary.
Old Jan 25, 2006 | 07:02 PM
discrete's Avatar
Why does it make a difference if you use a burns collector versus another collector? Is their steel special?
I said that because I am sure that there are people who do it both ways. It's a comfort issue.
Old Jan 25, 2006 | 07:13 PM
burns has nice collectors, its easier to have it slip in and out. Makes things wayyyy much easier.
Old Jan 25, 2006 | 07:55 PM
BEEYOND's Avatar
Default Re: (synik)
the reason why i am asking is because when the runners get welded... the head flange doesn't exactly line up anymore since when welding the runners actually shrink.... again meaning improper alignment. even if you have an awesome JEG after you properly weld the runners together and try to assemble the unit altogether before you weld the head flange to the runner...you'll notice an off alignment...
any other methods......
thx for the help so far...
Old Jan 26, 2006 | 12:45 AM
hondaapi's Avatar
Default Re: (lsvtecpower)
i would like to know too :-)
92cxturbo
Welding / Fabrication
Apr 18, 2011 07:03 AM
hondaboy4life
Feb 28, 2007 08:26 AM
meanEG
Feb 2, 2006 07:15 PM
philipwight
Mar 9, 2005 10:19 PM
Optiks.
Nov 27, 2003 12:29 PM
