DIY Clutch Anyone?
Old Jan 25, 2006 | 12:52 PM
accordisslow's Avatar
Default DIY Clutch Anyone?
i've done some searching and i wanted to know if anyone knows anygood threads of DIY replacing cluth? on 94-97 accords?
Old Jan 25, 2006 | 01:47 PM
Slomies's Avatar
I replaced the clutch and flywheel on my 95 accord myself. I dont have a link to a DIY, but it's not that hard. Drain the tranny fluid (I believe I did that first when I did this), drop the tranny, change clutch, put tranny back on ...
Old Jan 25, 2006 | 05:08 PM
dvp95's Avatar
Default Re: (95AccordVtec)
Yeah that pretty much sums it up...lol. Although I did it on my h22 on my 96 accord its the same. Not really a tutorial on it. You have the helms manual? Just take out a few bolts and take out the tranny. Putting it back on is a bitch though to get it lined up. Maybe its just the h22 that was hard but it sucked. Relatively easy though.
Old Sep 1, 2009 | 09:09 PM
SycOsiS Type-S's Avatar
Default Re: DIY Clutch Anyone?
its always hard to line tranny up. bout to do this on my sis car. boost of confidance on how easy u guys make it sound. I have an RSX-S and ive done my clutch. was tough but easy at the same time.
Old Sep 2, 2009 | 12:56 PM
213374U's Avatar
0x5359-0055
Community Builder
Why was it so hard for you 2 to "line the tranny up" when re-installing? As long as you have the little plastic alignment tool that comes with clutch kit's (and you use it properly), you should have no problem with alignment. Can't count how many times I've dropped the tranny for one reason or another.
Old Sep 2, 2009 | 04:00 PM
alkoholikwun's Avatar
the manual tranny is really light in weight, so my best technique for lining up the tranny to the motor is to get under it and "bench press" it. im 5'6, 135lbs, and its pretty easy, everytime.
Old Sep 5, 2009 | 12:27 PM
bronson39's Avatar
so on my 94 honda accord ex. i can just let the tranny drop from the bottom and take it apart.
clean4dr
Dec 3, 2006 01:40 PM
JDM_SOHC
Sep 18, 2006 08:49 AM
13link EG
Jul 30, 2005 08:53 PM
invboost
Nov 15, 2003 11:41 AM
