where does the radiator fan plug into?
b18a1
same as title...
i have all the wiring hooked up except the radiator fan... and there is no open plug for it so am i missing something?
also
on the back side of the engine below the ITM there is a plug with two femle connectors in a rubber boot it with two wires one wire for each femal end... does one have to be on the left and the other on the right or it doesn't matter?
thanks
same as title...
also
thanks
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by rewerbcrx »</TD></TR><TR><TD CLASS="quote">b18a1
thanks
that is the cooling fan switch and the wires can go either way - it is just a switch
thanks
</TD></TR></TABLE>that is the cooling fan switch and the wires can go either way - it is just a switch
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jlicrx »</TD></TR><TR><TD CLASS="quote">
that is the cooling fan switch and the wires can go either way - it is just a switch</TD></TR></TABLE>
thanks!!!!
okay it seems like your the only one that answers any of my questions lol
how about the radiator, where do i plugg it in ? on an HF harness with a b18a in her?
thanks!!!!
I remember reading somewhere that the B17 has a temp switch that is activated by oil temp on the back of the block. Is this the same as the B18A1?
it doesn't come off of the engine harness - the connector for the fan should come off the harness by the passenger headlight - kind of below the battery tray and attached to the side of the frame rail - round connector with 2 wires
the plug was white... and i feel like an idiot it was tucked around so i couldn't see it ... i actually acidently tugged on it and found it lol thanks though
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by rewerbcrx »</TD></TR><TR><TD CLASS="quote">the plug was white... </TD></TR></TABLE>
hmm. isnt that peculiar. what year is your EF? my plug is green, i have a 90 hatch.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by red_EF9Si »</TD></TR><TR><TD CLASS="quote">
hmm. isnt that peculiar. what year is your EF? my plug is green, i have a 90 hatch.</TD></TR></TABLE>
i have 88 HF and the part of the connector that is on the fan is green, but the part coming off the harness that plugs into the fan connector is white
, but the part coming off the harness that plugs into the fan connector is white</TD></TR></TABLE>
bingo
bingo
Skunk.Werks
May 17, 2005 07:45 PM
