Squeeking noise when i turn on the engine!
There's some squeeking noise when i turn on the engine and it seems to stop after 10 secs. Is it a belt? how would i know if its a timing belt or some other. I just bought it and the car runs fine. is the noise a major problem? should i get it fixed
Thanks.
Thanks.
the squeaking that is bothering you comes from one of your belts. just find where it is coming from and tighten it up. my friend had the same problem and a mechanic fixed his for free so i dont think it would cost you anything if you located the problem.
belts need to be replaced if they are cracked or scruffed up...i believe the adjusting bolt is a 12mm...correct me if im wrong...im not too sure cuz i lost the original mount bolt..and used a different one
Zuerst
Jan 13, 2004 11:33 AM
