Replaced headlights but fitting problem
Ok so installed new headlights on my 01 Accord, only problem they dont seem to fit exactly right.
Is there any wey i can adjust the new lights w/ out taking the bumper off?
There seems to be a little gap above the right light, it sits little too low and little too far to the centre of the vehicle. The vehicle has no frame damage.
What screws should i loosen to adjust this?
I loosened the top screw and the side screw but not much help :/
Is there any way i can adjust the height/alignment of the lights?
Oto
remove and reinstall your headlights. They should be straight when you insert them. The adjustments can be made by moving the screws at the top of the head light. Before adjusting them make sure that they are properly installed.
rasinhell
Feb 17, 2005 04:35 AM
b18bme
Sep 18, 2004 07:13 AM
