Name that part!
Old Jan 25, 2006 | 12:19 AM
slo90si's Avatar
Default Name that part!
Alright tommorow I am putting in my b16a with lsd in my 90 crx si and I dont know what this silver box thing is on the back of the transmission.
Another thing is I can't find where to plug in the speedo cable. If anybody can help me with this that would be awesome
Old Jan 25, 2006 | 12:54 AM
DEIVIONCRX's Avatar
Default Re: Name that part! (slo90si)
what tranny is that
i cant tell for shure, but i think thats a Electronic VSS(Speed Sensor)
if thats what it is you will need to take it out and get a Cable VSS and plug you speedo cable into it
or get a different Gauge cluster and Wire up the Electronic VSS
Old Jan 25, 2006 | 01:08 AM
slo90si's Avatar
The transmission is a y1 with lsd. I thought that this transmission had the gear driven speedo
Old Jan 25, 2006 | 01:23 AM
slo90si's Avatar
Can somebody please confirm if this is an electric vss?
Old Jan 25, 2006 | 03:35 AM
Davep's Avatar
yes it is
Old Jan 25, 2006 | 04:42 AM
crx_88_si's Avatar
jdm 89-91 SiR had electronic speedo
Old Jan 25, 2006 | 08:37 AM
XJamesX's Avatar
Default Re: (crx_88_si)
yes that is an electric speedo. If you want ot swap in a cluster from a newer integra or civic 92 and up then that speeedo will work. If you are going to use your stock crx custer then you need to get a cable speedo from any88-91 civic/crx.
-James-
Old Jan 25, 2006 | 10:46 AM
31flavorscivic's Avatar
Default Re: (XJamesX)
good excuse to get the EF SIR cluster
Old Jan 25, 2006 | 11:19 AM
slo90si's Avatar
Default Re:
Alright thanks guys, lets say I get an Sir cluster, will it be a direct swap into my crx? otherwise I guess ill just swap in a cable speedo. thanks for the help
Old Jan 25, 2006 | 11:31 AM
user 72830283's Avatar
well you're gonna need to run the wire from the this receptacle to the SiR gauge cluster, as i'm sure your USDM EF gauge cluster isnt electronic vss ready..
Old Jan 25, 2006 | 12:44 PM
integra95gsr's Avatar
replacing the VSS is much easier. plus its fun to burry the needle on the stock ef gauge!..lol
the VSS from your stock SI tranny will fit.. just swap them..
Old Jan 25, 2006 | 12:46 PM
Pee Wee's Avatar
Default Re: (integra95gsr)
its easier to just put your d series vss in.
Old Jan 25, 2006 | 01:58 PM
88crxvtec's Avatar
Default Re: (EF8opey)
I just took the top part of the electric vss off. this will allow you to use you exisiting cable. Keep the top part in case you ever want to wire in the sir cluster.
I used mine this way for 2 years without any trouble.
Old Jan 26, 2006 | 09:44 PM
Default Re: (88crxvtec)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 88crxvtec &raquo;</TD></TR><TR><TD CLASS="quote">I just took the top part of the electric vss off. this will allow you to use you exisiting cable. Keep the top part in case you ever want to wire in the sir cluster.
I used mine this way for 2 years without any trouble.</TD></TR></TABLE>
i think there are more than one speed sensor.. but this one he has i dont think it is possible, i just did a swap last month (b16a into civic with y1 tranny) and it had the same VSS as this guy, but it wasnt possible to use the cable..
ohaileo
May 9, 2017 10:41 AM
azazello
Sep 16, 2010 10:39 AM
rewerbcrx
Jul 19, 2007 04:28 PM
b18crx
Feb 10, 2004 06:25 AM
HT Chaplain
Apr 16, 2003 11:05 AM
