Type R Suspension, How much different?
I plan on buying an Integra in the near future, Would Love a Type R but funds are tight, therefore, I would at least like to have the feel of one(in one aspect). I am unfamiliar with the characteristics in the suspension regarding the integra base, Gs-r, and also the Type R. Could someone tell me what is different between each model from RS,GS, LS then to GS-R, to Type R, but only the suspension? I was wondering the difference in shocks, spring rate, as well as sway bars. Any and all help will be Greatly Appreciated.
Thanks,
Matt
Thanks,
Matt
you might try the type r forum. just a suggestion, sorry i cant answer your question. i know the rear and front anti roll bars are different, type r has the 22mm in the rear i cant remember what the front was.
ITR/GSR have the same front sway bar, ITR has 22 (23jdm)mm rear sway bar. The springs are stiffer (180ft/ 240 progressive Rear) and the lower the car about 15mm. Rear LCA's are totally different. Shock are stiffer. ITR has extra stiffener bars.
I am sure there are more, but that is all I can come up with right now.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Racermech »</TD></TR><TR><TD CLASS="quote">ITR/GSR have the same front sway bar, ITR has 22 (23jdm)mm rear sway bar. The springs are stiffer (180ft/ 240 progressive Rear) and the lower the car about 15mm. Rear LCA's are totally different. Shock are stiffer. ITR has extra stiffener bars.
I am sure there are more, but that is all I can come up with right now.</TD></TR></TABLE>
lighter, stronger body and panel welds...
