Got Some Quick LSVTEC Questions... Opinions, suggestions...
Block
b18a block w/ARP head & main studs
b18a crank [balanced]
b18c5 oil pump
b16a water pump [22t]
b18a rods [balanced] shaved small end to fit pistons shot peened w/ARP rod bolts
b18a OEM honda bearings
b18a head gasket w/enlarged dowel pin holes
b16a PR3 pistons [balanced] w/wrist pins
Golden Eagle LSVTEC conv. kit
b18a baffled oil pan and oil pick up (i may switch to GSR girdle, pan and pick up)
b18c1 timing belt & tensioner
b18a lower timing covers
Head
b16a gen1 head w/slight pnp
b16a gen1 cams w/stock gears
b16a obd0 distributor
b16a upper timing belt covers
b16a oem head kit [gaskets]
b16a intake manifold w/hondata im gasket
b18a throttle body
b18a fuel components (rail, injectors, lines, etc...)
b18c5 red "ITR" valve cover
Management
TurboEdit on a PR3
LM-1 Wideband O2 Sensor
possible conversion to OBD1 and use crome or uberdata [street tune w/LM1 wideband]
over view
This is going in my 1990 Integra sedan.
I just want to make sure the setup I have planned is a decent one.
I'm asking for validity. I need to be sure that the setup is going to be decent. Maing sure that it will be reliable for a daily driver. I know going w/forged internals would be more beneficial, but, I dont want to venture into that right now. So, give me some insight, let me know what you think or if you have any other suggestion.
b18c5 oil pump
Head
b18a throttle body
Management
TurboEdit on a PR3
over view
SilverStreak02
May 19, 2009 06:25 PM
bks84
Apr 13, 2006 02:55 PM
