CRX 3" Thermal blues ...
Old Jan 24, 2006 | 08:09 PM
kess's Avatar
Default CRX 3" Thermal blues ...
Just bought a 3" dia Thermal cat-back for my '90 CRX Si. The foreward flange does not mate to my OEM cat. What else do I need to install the kit? BTW: I have a Neuspeed header that I plan on keeping on the car.
Old Jan 24, 2006 | 09:42 PM
DEIVIONCRX's Avatar
Default Re: CRX 3" Thermal blues ... (kess)
this is wierd, it should
are you shure the cat is OEM, what does the flang look like on the cat is it the typical 3 bolt triangle flange
you might have to get a muffler shop to make you a "test pipe" normal triangle flange one side and normal 2 bolt flange on the front to bolt to the header
Old Jan 25, 2006 | 09:39 PM
kess's Avatar
Default Re: CRX 3" Thermal blues ... (DEIVIONCRX)
I ran a 'test pipe' once but had to take it off - with the supercharger it was too loud for the street. I just recieved email from the seller. He ran his CRX in the One Lap of America, and had a 'test pipe' on the car.
Yes, both the OEM cat and the 3" Thermal have the standard triangular exhaust gaskets. Only one is 1" bigger than the other.
Another way to get it done may be to take it to my local muffler shop. The owner is a dirt track racer and understands fabricating. Perhaps they can cut my stock cat and weld on a 3" collector.
Old Jan 25, 2006 | 10:03 PM
DEIVIONCRX's Avatar
thats what id do, or just pick up a cheep carsound cat and have him weld the flange to it
Old Feb 2, 2006 | 09:33 AM
mintef's Avatar
what the hell are you talking about a thermal 3" is only to be used on turbo applications and you can't use it with a stock cat as most thermal dealer will tell you before purchasing it.
Old Feb 2, 2006 | 09:34 AM
mintef's Avatar
sell me yours and buy the 2.25" which is what you need unless you're turbo
Old Feb 2, 2006 | 11:08 AM
Tippyman's Avatar
Default Re: (mintef)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mintef &raquo;</TD></TR><TR><TD CLASS="quote">what the hell are you talking about a thermal 3" is only to be used on turbo applications and you can't use it with a stock cat as most thermal dealer will tell you before purchasing it.</TD></TR></TABLE>
that's what i was thinkin...
Old Feb 2, 2006 | 07:30 PM
kess's Avatar
Default Re: (Tippyman98)
So thats why I bought a Thermal cat. Read my origional post. I was looking for a cat to fit the exhaust. Thermals E134 comes with a flange allowing you to bolt it to a turbo downpipe or a header (which I have).
TheCrimsonGhost666
Jan 9, 2012 05:42 PM
azn_88
Jun 15, 2008 09:49 PM
kess
11
Feb 2, 2006 07:24 PM
srv3fender
Mar 25, 2005 10:04 AM
sohcvtec66
Feb 25, 2004 06:49 PM
