s2000 Cluster Pinout
Old Jan 24, 2006 | 06:32 PM
crx^2yosolo's Avatar
Default s2000 Cluster Pinout
TOO MANY, im the first? i will post the PINOUT for S2000 Cluster!! i try, i try and i can't get the MPH and Temp 2 work!! i can't get MPH pulse right and i can't get the right temp signal from my Eg6.. but this S2000 cluster is Great!! only A few with this cluster in civic and integra!! HERE ARE THE PINOUT
PIN--------COLOR/STRIPE-----FUNCTION
A1---------EMPTY
A2---------EMPTY
A3---------EMPTY
A4---------BLUE/BLACK--------TRUNK OPEN LIGHT
A5---------WHITE/RED---------(CUT) DON'T USE
A6---------LIT BLUE/RED-------(CUT)
A7---------PINK------------------(CUT)
A8---------GREEN----------------DOOR OPEN
A9---------BLACK/WHITE-------(CUT)
A10--------RED/YELLOW--------CUT
A11--------RED/BLUE------------CUT
A12--------BLACK----------------*GROUND*
A13--------EMPTY
A14--------BLACK----------------*GROUND*
A15--------RED/YELLOW---------CUT
A16--------RED-------------------DIMMER
A17--------RED/BLACK----------GAUGE LIGHT
A18--------BLACK/YELLOW------SHIFT LIGHT --S2000 CLUSTER GOT BUILT IN SHIFT LIGHT, U CAN CONNECT 2 AUTOMETER 2 STEP OR 3 STEP..
A19--------YELLOW---------------*POWER*
A20--------EMPTY
A21--------WHITE/RED-----------CUT
A22--------EMPTY
B1----------EMPTY
B2----------BLACK/YELLOW---CHECK ENGINE LIGHT (S2000 GOT 2 OF THIS) CIVIC AND INTEGRA DON'T USE THIS
B3----------BLUE/YELLOW-----CRUSE CONTROL LIGHT
B4----------BLUE/ORANGE-----CUT
B5----------BLUE----------------RPM *BEST PART OF THIS CLUSTER*
B6----------BLUE/BLACK-------CUT
B7----------BLUE/RED-----------SEAT BELT
B8----------WHITE/BLACK-------CUT
B9----------YELLOW/GREEN----TEMP GAUGE
B10---------PINK----------------AIR BAG
B11---------RED/WHITE--------CUT
B12---------BLUE/RED-----------ABS
B13---------BLUE/WHITE--------MPH
B14---------YELLOW/BLUE------EPS
B15---------EMPTY
B16---------GREEN/WHITE-----BRAKE LIGHT (S2000 GOT 2 OF THIS) CIVIC N INTEGRA DON'T USE IT
B17---------WHITE/BLACK------CUT
B18---------GREEN/RED--------BRAKE LIGHT
B19---------BLACK/WHITE-----CUT
B20---------EMPTY
B21---------YELLOW/BLACK-----FUEL GAUGE
B22---------WHITE/BLUE--------BATTERY LIGHT
B23---------EMPTY
B24---------YELLOW/RED-------OIL LIGHT
B25---------GREEN--------------CUT
B26---------GREEN/ORANGE----CHECK ENGINE LIGHT
B27---------YELLOW/BLUE------CUT
B28---------GREEN/RED--------RIGHT TURN SIGNAL
B29---------EMPTY
B30---------GREEN/YELLOW----LEFT TURN SIGAL
Old Jan 25, 2006 | 01:05 AM
dclsvtec's Avatar
Default Re: s2000 Cluster Pinout (crx^2yosolo)
cool
Old Jan 25, 2006 | 01:32 AM
J-Brooks's Avatar
Default Re: s2000 Cluster Pinout (dclsvtec)
pics?
Old Jan 25, 2006 | 06:57 AM
93_teg_CT's Avatar
Default Re: s2000 Cluster Pinout (J-Brooks)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by J-Brooks &raquo;</TD></TR><TR><TD CLASS="quote">pics?</TD></TR></TABLE>
Old Jan 25, 2006 | 07:38 AM
Solscud007's Avatar
I thought there was a speed governor thing that is different on S2000 than Civic or integ.
Old Feb 21, 2006 | 09:43 PM
cwtech's Avatar
i also heard this does not work.
crx^2yosolo
10
Sep 27, 2011 01:10 PM
miamiel
Apr 6, 2011 06:13 PM
crx^2yosolo
Jan 26, 2006 11:40 AM
