ATTN: 6th gen V6 owners.
Old Jan 24, 2006 | 06:01 PM
-Bionic-'s Avatar
Former Sponsor
Default ATTN: 6th gen V6 owners.
To make a long story short, I'm installing hood dampers to my 4cyl Accord that didn't come with it.
The hood for the 4cyl and 6cyl accord has the same part number. I got the dampers/gas shocks with the ball joint piece on either end, but I can't seem to figure out to install it.
Do I need another piece, or should I start considering drilling holes?
TIA
Old Jan 24, 2006 | 06:27 PM
YeuEmMaiMai's Avatar
Default Re: ATTN: 6th gen V6 owners. (-Bionic-)
I would go to a honda dealer and ask them how to install them. They will usually be more than helpful......
#13, #21, #23 are the parts you need
Old Jan 24, 2006 | 06:40 PM
-Bionic-'s Avatar
Former Sponsor
Default Re: ATTN: 6th gen V6 owners. (YeuEmMaiMai)
Hey. Thanks a lot for the quick reply.
Yes I have a print out of that diagram, and I have parts 13 and 21.
I dont' think #23 is helpful since I'm pretty sure it bolts the hinge to the hood, like #22 bolts the hinge to the engine bay.
I was told by a friend that the damers/shock bolts to another metal bracket.
The Honda dealer hasn't helped me out one bit other than printing out the same diagram to me.
Thanks.
Old Jan 24, 2006 | 06:47 PM
I would try to talk to the guys in a body shop if they have one.....
Old Jan 24, 2006 | 07:03 PM
Corruption's Avatar
what's the purpose of it? making the hood less susceptible to damage if closed or dropped incorrectly?
Old Jan 24, 2006 | 08:04 PM
philadd's Avatar
Default Re: (Corruption)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Corruption &raquo;</TD></TR><TR><TD CLASS="quote">what's the purpose of it? making the hood less susceptible to damage if closed or dropped incorrectly?</TD></TR></TABLE>
it removes the need for the hood prop.
makes lifting the hood much easier.
The V6 models were the only ones that came with it.
Old Jan 24, 2006 | 08:11 PM
Default Re: (philadd)
yeah, they didn't want anything to obstruct the view of the magnigficant engine that they put in there :D
Old Jan 24, 2006 | 08:38 PM
-Bionic-'s Avatar
Former Sponsor
Default Re: (YeuEmMaiMai)
Anyone with a V6 6th gen accord on this board? With hood dampers?
Modified by -Bionic- at 9:53 PM 1/24/2006
Old Jan 24, 2006 | 08:43 PM
Default Re: (-Bionic-)
yeah, want you wan to know...........
Old Jan 25, 2006 | 07:20 AM
dodge-honda's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by -Bionic- &raquo;</TD></TR><TR><TD CLASS="quote">Anyone with a V6 6th gen accord on this board? With hood dampers?
Modified by -Bionic- at 9:53 PM 1/24/2006</TD></TR></TABLE>
Yes I have a 99 Accord V6 with hood dampers, what did you want to know???
Old Jan 25, 2006 | 07:22 AM
-Bionic-'s Avatar
Former Sponsor
Default Re: (dodge-honda)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dodge-honda &raquo;</TD></TR><TR><TD CLASS="quote">
Yes I have a 99 Accord V6 with hood dampers, what did you want to know???</TD></TR></TABLE>
The hood for the 4cyl and 6cyl accord has the same part number. <U>I got the dampers/gas shocks with the ball joint piece on either end, but I can't seem to figure out to install it.
</U>
TIA </TD></TR></TABLE>
Old Jan 25, 2006 | 07:28 AM
kulrevon's Avatar
if you took a picture of the mounting I am sure that would help him.
Old Jan 25, 2006 | 08:25 AM
-Bionic-'s Avatar
Former Sponsor
Default Re: (kulrevon)
If you are tlaking to me...then I don't have a mounting point that's the problem.
If someone would be nice to take a picture of the mounting points on the V6 accord WITH HOOD DAMPERS installed, then that would be much appreicated.
Old Jan 25, 2006 | 12:23 PM
philadd's Avatar
I'd like to see it as well...
Old Jan 25, 2006 | 03:44 PM
luffy.'s Avatar
I think you might have to custom weld/fit it to make it work.
i've heard a few people try this and it doesn't really just connect/plugNplay.
Old Jan 25, 2006 | 03:47 PM
If the holes are not already in the hood you will have to do some drilling and reinforcing before mounting the brackets for the hood shocks.
Old Jan 25, 2006 | 04:03 PM
-Bionic-'s Avatar
Former Sponsor
Default Re: (whoagorgeous)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by whoagorgeous &raquo;</TD></TR><TR><TD CLASS="quote">I think you might have to custom weld/fit it to make it work.
i've heard a few people try this and it doesn't really just connect/plugNplay.</TD></TR></TABLE>
Yes..it's apparent that it's not plug and play. What I dont understand it is that the V6 and 4cyl have the same hood. It's the same part number. The 4cyl hood has holes on the side, but the shocks with the ball joints cannot be screwed in. The hole is too large, which tells me that I need another piece. However, looking at the diagram there is no more part.
There are thousand of V6 owners that have hood dampers, surprised none has put in any good info. It's easier to find information about D16 swaps in accords than my question.
Old Jan 25, 2006 | 04:58 PM
OK here is how they attach
#21 screws into the side of the hood about halfway between the front and back
#19 bolts to the firewall in the corner just below the cowl ( you will have to dril and use self taping screws)
#13 attaches to #21 and #19
Old Jan 25, 2006 | 05:04 PM
-Bionic-'s Avatar
Former Sponsor
Thanks.
Last time you told me that I needed part #23, so I guess you found this information somewhere else.
Yes the #21 should go into the hood, but the hole that is there now is too big for #21. #19 is a new thing...and I"ll swing by the dealership tomorrow to pick that up.
Thanks.
Old Jan 25, 2006 | 05:27 PM
I actually went out and opened the hood on my car and it is attached exactly how I showed you.
-Bionic-'s Avatar
Former Sponsor
Thank you very much.
Old Jan 27, 2006 | 08:07 AM
-Bionic-'s Avatar
Former Sponsor
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by YeuEmMaiMai &raquo;</TD></TR><TR><TD CLASS="quote">I actually went out and opened the hood on my car and it is attached exactly how I showed you.</TD></TR></TABLE>
So much for that.
I went to the Honda Dealer, and #21 is called a Drain Valve used to colled or shut the water from the windshield.
I am just going to tap and thread into the hood and wall.
Old Jan 27, 2006 | 09:25 AM
Eddiebx's Avatar
beware of tapining into the hood and firewall, i dobut that material is thick enough to support much load. its sheet metal.
Old Jan 27, 2006 | 10:19 AM
Default Re: (Eddiebx)
go look at a 6th gen V6, you will see that it is just fine to attach the hood strut to the firewall where indicated.
Old Jan 27, 2006 | 10:45 AM
Eddiebx's Avatar
i would imagine that honda would have welded a nut behind the firewall for the struts to bolt onto. the sheet metal is pretty thin and not exactly too reliable to try to tap threads onto. but i wouldn't be surprised with the 6th gen, the build quality sucks compared to the 4th and 5th gens. they cut corners where they could.
