which cam should i go with for my 2000 GSR
Old Jan 24, 2006 | 04:50 PM
colored's Avatar
Default which cam should i go with for my 2000 GSR
how much should i pay for type R cams for my 2000 GSR or sohuld i just buy like a skunk2 cam. i'm looking to turbo my car after i finish the interners. i want to know which cam is best for my sitution and how much should i pay for it?
Old Jan 24, 2006 | 06:33 PM
H23 Power's Avatar
Default Re: which cam should i go with for my 2000 GSR (colored)
if your going turbo, leave the stock cams in.
Old Jan 24, 2006 | 06:46 PM
Keats97turboteg's Avatar
Either leave the stock ones in or do the type r cams. Do not go with any thing else because thay are not as strong as the acura cams. Other cams with wear much quicker.
Old Jan 24, 2006 | 06:59 PM
fergy016's Avatar
Default Re: which cam should i go with for my 2000 GSR (Keats97turboteg)
I went with sk2stg1 cams. I found myself a lil lean on the vtec cross over. Which means injectors were needed.
sk2stg1 cams are smog legal. You can find them new for $545 shipped.
Sk2's are a bit more agressive the the itr cams.
If your looking to turbo the car, you will make more power with the gsr cam then either the sk2/itr cams. More time for the air to compress giving you more power. I am going to swap my stock cams in when I finally go fi as well. Looking to build my gsr to 400hp.
Old Jan 24, 2006 | 07:02 PM
EG6 ON STANDS!'s Avatar
Default Re: which cam should i go with for my 2000 GSR (fergy016)
most turbo gsr's always run the oem cams. even ls-vtec turbo cars prefer the gsr cams. stick with your oem cams.
9341civic
Jun 1, 2005 12:31 PM
MysteriousGSR
Feb 2, 2003 09:03 AM
Black Sheep
Jun 21, 2002 06:59 AM
MysteriousGSR
Apr 15, 2002 06:47 PM
VRxDReGoNxGSR
Jul 15, 2001 10:16 PM
