Rear Sway Bar: Is ST worth the $
Old Jan 24, 2006 | 04:34 PM
Nisif's Avatar
Default Rear Sway Bar: Is ST worth the $
I'm thinking about installing a rear sway bar on my 91 Dx hatch. Have any of you upgraded your oem Si rear sway for a Suspension Technique rear sway? Was it worth it? Just wondering if I should shell out the extra $ for the ST or not, or just pick up one from an Si.
Old Jan 24, 2006 | 04:35 PM
Tyson's Avatar
Default Re: Rear Sway Bar: Is ST worth the $ (Nisif)
aside from tires, upgrading your rear swaybar is the best mod you can do to improve handling.
Old Jan 24, 2006 | 04:49 PM
Nisif's Avatar
Default Re: Rear Sway Bar: Is ST worth the $ (Tyson)
Good point, but is the ST rear sway that much better than a stock Si?
Old Jan 24, 2006 | 04:52 PM
Tyson's Avatar
22mm vs 15mm? yes.
besides, ST is made to adapt to your DX with its own hardware. youre going to spend more time and perhaps money trying to get the Si bar to install in your DX because you dont have the LCA and you dont have the threaded holes for the stock brackets.
Old Jan 24, 2006 | 04:56 PM
Nisif's Avatar
Good clarification, didn't know the difference in diameter was that great
Old Jan 24, 2006 | 04:57 PM
wacrxguy's Avatar
I agree with Tyson it would be a lot of work to get the SI one to bolt up since your car never had a rear bar. The ST bar is a well built easy install and it does make a huge difference. Plus it is adjustable so it gives you a little tunability.
Old Jan 24, 2006 | 05:04 PM
jisu009's Avatar
Default Re: Rear Sway Bar: Is ST worth the $ (wacrxguy)
it's worth the $.
Just get the rear one though. No front or HF front is the way to go.
Old Jan 24, 2006 | 05:08 PM
Tyson's Avatar
Default Re: Rear Sway Bar: Is ST worth the $ (jisu009)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jisu009 &raquo;</TD></TR><TR><TD CLASS="quote">it's worth the $.
Just get the rear one though. No front or HF front is the way to go. </TD></TR></TABLE>
well that depends. i needed to bump up my front swaybar since im using stock springs. but i used OEM options, civic sedans or DA front swaybars. so still, dont bother with paying for the front ST bar. the ST front swaybar is also 22m, thats just too much.
Old Jan 24, 2006 | 05:13 PM
jisu009's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Tyson &raquo;</TD></TR><TR><TD CLASS="quote">
well that depends. i needed to bump up my front swaybar since im using stock springs. but i used OEM options, civic sedans or DA front swaybars. so still, dont bother with paying for the front ST bar. the ST front swaybar is also 22m, thats just too much.</TD></TR></TABLE>
agreed
Old Jan 24, 2006 | 05:25 PM
88 rex's Avatar
Worth the $$$
Old Jan 24, 2006 | 05:30 PM
CRX Toad's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Tyson &raquo;</TD></TR><TR><TD CLASS="quote">aside from tires, upgrading your rear swaybar is the best mod you can do to improve handling.</TD></TR></TABLE>
Old Jan 24, 2006 | 06:06 PM
ex voto's Avatar
Default Re: Rear Sway Bar: Is ST worth the $ (CRX Toad)
Love mine on my EX.
Old Jan 24, 2006 | 06:24 PM
fourthgenhatchB17's Avatar
Thought it was 19mm? I will measure again next time im on the ground. i have both the ST front and rear sway bars and i have to say, my car feels damn good, hehe
Old Jan 24, 2006 | 06:25 PM
Junkyard2000's Avatar
Default Re: Rear Sway Bar: Is ST worth the $ (fourthgenhatchB17)
will this fit with an apex ws2 exhaust?
Old Jan 24, 2006 | 06:26 PM
Tyson's Avatar
the ST bar for the DA integra is 19mm. it MAY fit CRX's, but its supposed ot use the original hardware. actually, id really like to know if that works. because it would just be another tuning option.
the crx bar is definately 22mm.
Old Jan 24, 2006 | 06:58 PM
Default Re: Rear Sway Bar: Is ST worth the $ (Junkyard2000)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Junkyard2000 &raquo;</TD></TR><TR><TD CLASS="quote">will this fit with an apex ws2 exhaust?</TD></TR></TABLE>
A friend of mine has the WS exhaust on his EF Si hatch, not sure sure if its the I or II version, but it hits the stock Si bar. Apexi put the connection flange right at the spot where the piping intersects the bar. Dumb ***** over at Apexi
Tyson, I will get the O.D. measurement of the front sway bar off my car tomorrow.
Old Jan 24, 2006 | 07:53 PM
cbp_crx's Avatar
yes definatly worth the cash
patrickstar
Mar 1, 2009 09:15 AM
Cuong-nutz
Suspension & Brakes
Aug 8, 2005 03:45 PM
p1driftfiend
14
Feb 23, 2004 12:18 PM
Odiedogcx
Feb 5, 2004 01:45 PM
spun Vtec
Nov 13, 2002 05:51 PM
